Sponsored by: CARiD
Cluster lighting help!
Old May 29, 2007 | 07:08 PM
na4now's Avatar
na4now
Default Cluster lighting help!
I change a few burnt bulbs, in the cluster, in my SC. I put it back in, and the backlighting isnt working at all!
The needles are fine, turn signal and brights indicator are fine, but NO backlighting for the gauges.
What could I have done? If I have the polarity backwards on one bulb, would it cause this?
Old May 30, 2007 | 11:13 AM
na4now's Avatar
na4now
Dang, I thought someone would know. I dont guess I could of posted this in the sc300 section?
Old May 30, 2007 | 11:33 AM
tritron's Avatar
tritron
May be something is not pluged in correctly. Did you check dimer setting.
Where did you get parts?
Old May 30, 2007 | 02:08 PM
na4now's Avatar
na4now
I only changed three bulbs. I got them from an electronics supply place. I plugged in the dimmer, and adjusted it back and forth. It adjusted the needle brightness, but the backlighting is out.
Old May 30, 2007 | 06:33 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Backlight is designed into the three top ribbon cables.
Old May 30, 2007 | 08:00 PM
na4now's Avatar
na4now
So I should pull it out and make sure theyre connected properly? I sure hope its as easy as that.
Old May 30, 2007 | 08:35 PM
tritron's Avatar
tritron
yes that the first step to take.
Old Jun 3, 2007 | 06:36 PM
tritron's Avatar
tritron
did you fix it?
Old Jun 4, 2007 | 02:52 PM
na4now's Avatar
na4now
Not yet. Ill give an update.
Oconee1985
Oct 20, 2016 03:43 PM
Phrekazoid
Feb 24, 2012 08:06 PM
evilninja
Dec 17, 2010 11:07 PM
L. L. S.
Jun 6, 2005 02:30 PM
