Sponsored by: CARiD
Best HID Kit
Old May 19, 2007 | 05:16 PM
Dj_AmtraX's Avatar
Dj_AmtraX
Default Best HID Kit
Anyone used this kit before? The vendor said that the relay is not required or recommended for this kit. If you used it before, please post your review.
Thanks!
Old May 19, 2007 | 05:17 PM
T.K.O.'s Avatar
T.K.O.
I dunno I just ordered from www.mobilehid.com 2 days ago and I've heard nothing but positive feedback. They're shipping right now so PM me and I'll let ya know how they are in a few days.
Old May 23, 2007 | 11:40 AM
Dj_AmtraX's Avatar
Dj_AmtraX
I installed the kit on my 2006 Civic. So far everything works fine. I did not use the relay. Here are some pics.
Old May 23, 2007 | 12:39 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
i like my mobilehid.com kit too... (of course free helps), but really, they're beautiful... and easy to install (I did use the relay)
Old May 23, 2007 | 05:03 PM
DarKnight's Avatar
DarKnight
You don't really need to use the relay for the lowbeams, just for the highs and fogs.
Old May 23, 2007 | 05:51 PM
mitsuguy's Avatar
mitsuguy
huh?
low beams need the relay more than highs do...
stock highs are what, 65 watts? lows are 55 watts?
HID's pull more than 55 watts on startup, then average about 35 watts...
I've seen / heard too many horror stories of melted wiring, blown out ballasts and bulbs using the stock wiring... the mobilehid kit wiring harness is sooooo easy to use - it takes literally 2 minutes to wire it to the battery terminal...
Old May 24, 2007 | 07:20 AM
mitsuguy's Avatar
mitsuguy
It's not the wattage that's higher on startup, it's the voltage. I've been running my HID's for over a year and a half with no harness with no problems.
um, no... not saying you haven't had problems, but people have...
it is the wattage / amperage that is higher on startup...
a vehicle charging system is always 12.5-14.4 volts, no matter what bulb or lighting system is in there...
after the transformer, the voltage is higher, yes, but the transformer (ballast) can only pull whatever voltage the vehicles charging system supplies it...
now, we know that HID ballasts draw more power on start up, and, by following V=I*R, if voltage stays constant, and resistance stays constant, that amperage has to go up, wattage is derived from amperage and voltage
Old May 24, 2007 | 07:24 AM
RedPhoenix's Avatar
RedPhoenix
I ran my hids without relay aswell for a good amount of time on my last car.
Old May 24, 2007 | 07:50 AM
T.K.O.'s Avatar
T.K.O.
mobilehid workin great for me
Old May 24, 2007 | 08:28 AM
DarKnight's Avatar
DarKnight
Originally Posted by mitsuguy
huh?
NIAautoDesign
CL Vendor Products for RC
Jun 15, 2021 08:17 PM
Sango
Feb 3, 2012 09:39 AM
graphX250
Lighting
Apr 25, 2011 12:26 PM
CarlitosPR
Apr 7, 2008 08:33 AM
SCpwner
Lighting
19
Jan 9, 2008 01:48 PM
