Sponsored by: CARiD
Dome LIghts
Old May 16, 2007 | 08:16 PM
Bigrahizzl's Avatar
Bigrahizzl
Default Dome LIghts
Guys i just recently installed the 5 LEd refractor bulbs and i noticed that they dont turn on when i appraoch the car like the old bulbs did. Does anybody know why is this so.
Old May 16, 2007 | 08:33 PM
RU514's Avatar
RU514
Do you have the button pressed "Door" to turn it on? I have LED's everywhere in my car and I have no problem at all.
Old May 16, 2007 | 08:44 PM
Bigrahizzl's Avatar
Bigrahizzl
Yea i do b/c the way i can tell is from the back dome light. I didnt change it out yet cuz i dont have the bulbs. When i approach the car the back dome light turns on but the front one which i changed dont. But when i open the door they turn on but not when i approach it.
Old May 16, 2007 | 08:47 PM
Bigrahizzl's Avatar
Bigrahizzl
Could it be because i only have two refractor bublbs in the front dome. I only had two so installed them and i will install the third one later which is going to go in the middle.
Old May 17, 2007 | 10:30 AM
RU514's Avatar
RU514
Yeah, that is your problem. Ok, when you approach your car, only the MIDDLE bulb in the front dome turns on. Since there are 3 bulbs in the front dome, the outer 2 don't light up when approcaing the car and only the middle one lights up (to save power). Same with the back where only 1 bulb lights up. However, when you open the doors, all the lights in the front dome and rear dome turn on.
So to fix your problem, you are going to need to switch one bulb and put it in the middle.
Hope that helps
Old May 17, 2007 | 11:42 AM
Bigrahizzl's Avatar
Bigrahizzl
Hope that helps
Thanks dude that helps alot, Im planning on ordering them today then if not tomorrow. But thanks this helped alot i was worried.
Old May 17, 2007 | 07:25 PM
Bigrahizzl's Avatar
Bigrahizzl
Hey guys do you think that this light is good for the rear dome fitting
heres the link http://cgi.ebay.com/ebaymotors/V-LED...QQcmdZViewItem
Old May 19, 2007 | 05:37 PM
T.K.O.'s Avatar
T.K.O.
i have no problems with my LEDs.. i got em from superbrightleds.com
Haul
Sep 8, 2018 12:05 AM
Synetix250
Apr 5, 2013 01:39 PM
Mi1lion
Oct 16, 2012 01:14 PM
Och
Lighting
Oct 25, 2005 11:51 PM
Hameed
Lighting
13
Mar 5, 2005 01:59 AM
