2006 map lights
Hi, I just got a used 2006 ES330. The first thing I noticed is that the map lights do not seem to be wired to the dome light. I have the dome light in the "Door" position, and it works fine. When I open a door, the dome light turns on as expected. However, the map lights in the front do not turn on. Is this normal behavior? If so, is there an easy way to re-wire the map lights to the dome light so that both turn on when a door is opened?
Additionally, are there any good custom interior LED kits for the ES330? I already replaced the bulbs with LEDs, but custom LED boards for a vehicle will always beat standard LED bulbs.
rclab1
Jan 12, 2008 11:16 AM
