Weird HID bulb problem
Old May 11, 2012 | 08:52 PM
apdimitri's Avatar
apdimitri
Default Weird HID bulb problem
Tonight while driving home the drivers side HID bulb went out and I thought the bulb burned out. Then I got home and turned off the lights and then on again and it worked. What could be the problem since its not a burned out bulb?
Old May 11, 2012 | 09:51 PM
ddhleigh's Avatar
ddhleigh
Ballast or loose wire/connection.
Old May 11, 2012 | 10:02 PM
patbateman's Avatar
patbateman
Check the bulb first, it's most likely the problem.
Old May 12, 2012 | 12:43 AM
nitrotang's Avatar
nitrotang
That was the same problem I had. I swapped the bulbs out with new ones and that solved the problem.
Old May 12, 2012 | 01:03 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Probably the bulb.
Jeff
Old May 12, 2012 | 01:52 AM
gemini1's Avatar
gemini1
FNM President
Originally Posted by Jeff Lange
Probably the bulb.
Jeff
^^ I had same problem. Changed the bulb. no problem anymore!
Old May 12, 2012 | 02:11 AM
4U2eNv_8o8's Avatar
4U2eNv_8o8
Always a popular problem with HID bulbs based on my experience. If you play around with your headlight switch it'll come on a couple of times before the bulb decides to give up and die.
GRZMNKY
Jan 6, 2012 09:14 AM
Swishh
Jul 13, 2011 12:00 AM
TXES350
Mar 12, 2011 07:46 PM
ISCjonny
Dec 22, 2007 05:32 AM
stroker tj
Lighting
Nov 18, 2006 09:44 PM
