My high beam isnt turning on at all.
I tried changing teh bulbs.
I checked all the fuses.
Checked all the connections and then some and STILL they dont work.
Any ideas what it could be?
If they work during the daytime then maybe its the switch
They dont work at all.
Day Time. Or in my garage where I was working on them yesterday.
I sense a confusion [auto vs DRL].
I would suggest switching out of "auto" on the light switch stalk.
If you are "working on them", be aware that DRL ('98 did not have it) brings the two bulbs in series via the relays and electrical configuration is non standard [+12v source -> switch -> bulb -> GND]
Salim
I tried that already as well.
I put it just on the light on position and it still didnt turn on.
It seems like it wants to do it because I left the Fog lights on and it turns off the fogs when I switch to high beam.
The day time running lamps work perfectly.
And the emergency brake is NOT engaged either.
My car is a 2000 GS.
I switched the bulbs so I dont think its the bulbs.
Its 9005 on the highbeams and 9006 on the regular right?
