Sponsored by: CARiD
High beam problems
Old Sep 18, 2006 | 02:08 PM
salimshah's Avatar
salimshah
25 Year Member
Originally Posted by cpone
But I dont want to disable the DAR.
I just want my High Beams to work. LOL..
Use the link to locate/identify relays. Only.
salim
Old Sep 18, 2006 | 09:08 PM
Deception's Avatar
Deception
are you using 9006 bulbs? it could be a relay or fuse or even be a switch but check the bulbs
Old Sep 18, 2006 | 09:13 PM
Deception's Avatar
Deception
sorry double post
Old Sep 19, 2006 | 06:17 AM
cpone's Avatar
cpone
There can only be One
CL Folding 2,000,000
I am using 9005 I think on the highs.
And I checked the fuses but I a need to see where the fuse is on the GS300.
Is it over on the drivers side?
Old Sep 19, 2006 | 07:34 AM
Tammy's Avatar
Tammy
The fuse layout and locations are explained well in the owners manual.
Old Sep 19, 2006 | 01:42 PM
V8_Fan's Avatar
V8_Fan
If your DRL's work but highs don't, I suspect the DRL relay is malfunctioning. You should be able to pull the relay and test the pins according to the schematic. The circuit posted is definitely different than on the LX (simplified--low beams power DRL relay, so low's stay on when highs are on, meaning if you run HID's on lows, you won't be switching them on/off w/ the highs).
cbo111
Jul 14, 2020 12:39 AM
Gregor99
GX - 1st Gen (2003-2009)
Oct 29, 2018 07:11 AM
sinstrex
Dec 23, 2013 12:02 AM
-mb-
RX - 1st Gen (1999-2003)
Dec 14, 2006 01:27 PM
mcgong
May 26, 2005 07:38 PM
