High Beams Out
Old May 26, 2005 | 07:11 PM
mcgong's Avatar
mcgong
Default High Beams Out
I just noticed that my high beams are out. I checked all the fuses in the car and all of them seem to be ok. I checked the bulbs and none are burned out. All other lights work in the car. Does anyone know if there is a high beam relay that might be out or where one might be located. I don't hear a clicking noise with I flip the high beam switch. Thanks
Old May 26, 2005 | 07:15 PM
vicestan's Avatar
vicestan
Check the connection to the bulb, if the connection is not made to any 1 bulb they high beams wont turn on.
Old May 26, 2005 | 07:22 PM
mcgong's Avatar
mcgong
my drls work fine. Just when I flip the switch, the high beams stay dim and never go brighter. Do you think it might be the :"Dimmer DRL #2" relay?
Old May 26, 2005 | 07:38 PM
vicestan's Avatar
vicestan
Hmm, it wont be the drl relay because then your drl's wont work. It might be a busted relay, look in the lexus manual and look at the list with all the fuse's and check the once related to high beams, maybe you will find a dead one.
nayho
Jun 24, 2019 07:42 AM
suzieleigh
Feb 8, 2016 10:09 AM
ArtD
Dec 13, 2008 03:14 PM
IS_NIICE
Feb 14, 2008 03:39 PM
-mb-
RX - 1st Gen (1999-2003)
Dec 14, 2006 01:27 PM
