Sponsored by: CARiD
HID retrofit on RX300
Old Apr 1, 2005 | 09:46 AM
htd4555's Avatar
htd4555
Default HID retrofit on RX300
Hi,
I have a set of Philips ballasts and D2R bulbs (already rebased to fit 9006 housing) that I want to use in my 2001 RX300. However, when I plug the power connector from the ballast to the low beam harness, the HID light does not turn on. It works fine by connecting directly to the battery. Could someone please tell me what I 'm missing here?
Thanks,
htd4555
Old Apr 1, 2005 | 12:20 PM
PHML's Avatar
PHML
Master Thread Closer!!
Got pics?
Maybe there's NOT enuff juice from the lowbeam socket to powerup the igniter in the ballast. Im thinkin you may be missing something in your kit.
I got a Philips kit that connects directly to the battery and the lowbeam socket acts as the off and on switch to the ballast igniter.
Pete
Old Apr 1, 2005 | 12:39 PM
htd4555's Avatar
htd4555
Thanks for the reply. The Philips ballasts are LVQ-312 with built-in igniter. I had used this kit previously with an older LS400 with excellent result. May be, the RX300 low beam socket has a current limitation that only works with the Halogen bulb type. Are there any aftermarket parts available to overcome this?
htd4555
Old Apr 1, 2005 | 05:57 PM
rominl's Avatar
rominl
exclusive matchup
that's interesting, missing a better relay?
coz' the stock hid system work on my halogen 9006 plug no problem
Old Apr 3, 2005 | 05:23 PM
slawek65's Avatar
slawek65
Get new harnes with relay and fuses and You all set.
Old Apr 7, 2005 | 11:31 AM
htd4555's Avatar
htd4555
The OEM relay is made by Denso. Does anyone know a place to get the upgrade relay and harness? I contacted a local Lexus dealer and they only have the same OEM parts.
Thanks,
htd4555
Old Apr 14, 2005 | 12:09 PM
PHML's Avatar
PHML
Maybe your polarity is messed up....i remember the lowbeam socket and the connector from the ballast switches polarity on my kit....which blew my fuses. Check that.
Pete
Old Apr 22, 2005 | 10:55 PM
tiguy99's Avatar
tiguy99
Go to www.hidplanet.com and grab a harness from there and you'll be all set
Old May 2, 2005 | 08:41 AM
htd4555's Avatar
htd4555
It turned out that the polarity markings on the low beam harness are incorrect ("+" is actually ground and "-" is 12V). I did not experience this problem before with any OEM harness, but it should have been verified easily with a multimeter. Oh well, I got my HID working now. Thanks for all of your responses.
htd4555
dvzzz
GX460 / GX470 Classifieds
Jan 28, 2014 08:37 AM
ekaiman341
Lighting
Dec 14, 2012 02:46 PM
kpkim01
Lighting
Dec 9, 2009 12:26 PM
MrSypher
Lighting
Mar 24, 2002 05:06 PM
