Sponsored by: CARiD
retrofit problem: housing
Old Apr 2, 2004 | 12:14 PM
siniquezu's Avatar
siniquezu
Default retrofit problem: housing
Hey HID gurus, YES ALL THREE OF YOU! I may have to drill into my housing to get my new setup to fit properly. There will be a hole in the housing itself and part of the projector will stick out if it. I've seen some people use foam..... (*cough* HIDtech ) to "create a new housing." I was wondering if there are any other solutions or is the foam good enough?
Another question: If I wanted to seal it back up PERFECTLY WITHOUT using silicone, what type of glue is holding the headlight housing together?
Old Apr 4, 2004 | 11:26 PM
siniquezu's Avatar
siniquezu
No one?
Old Apr 5, 2004 | 01:31 AM
rominl's Avatar
rominl
exclusive matchup
retrofit isn't my area man
Old Apr 20, 2004 | 07:58 PM
BlkOnBlkGS's Avatar
BlkOnBlkGS
Hid FAQ
That link should be helpful and give you some pretty good ideas.
Old Apr 28, 2004 | 12:17 AM
tiguy99's Avatar
tiguy99
Ok...I can take a "stab" at it! Lol. Use JB Weld. That stuff pretty much holds anything together if you use enough of it. Walgreens sells it for like 3-5 bucks.
Update us on pics! BTW which HID setup will you be using? Like which brand projectors, Ballasts, Bulbs (color temp)? Will the projectors be DOT(US spec) or ECE (more advanced and better Euro spec)? Pics definately are helpful. its a language anyone can understand!
Mike
Old Apr 28, 2004 | 10:28 AM
siniquezu's Avatar
siniquezu
Mike
I actually don't have a problem with the mounting of the projector. I have a problem because my headlight housing is too small for the Bixenon solenoid. The motor will be relayed but the solenoid can't be. I have to either entend the housing, remove the solenoid, or scrap the projecto altogether.
BTW, the glue that manufacturers use is butyl rubber caulk. They purchase them in high volume and it is not commercialized.
Old Apr 28, 2004 | 01:51 PM
tiguy99's Avatar
tiguy99
Why not just get a smaller single xenon projector? Which car will you be retrofitting? If space is an issue, you can go Valeo ECE D2S or H7 projector with adapter. Either way, your output will be way sicker as well as the color and sharpness of the cuttoff. Its another option for you to consifer...other wise, cut a hole in the portion where your solenoid will go and mount them that way. The JB weld is to hold the projector in place. You still will end up using the factory silicon when refastening your lights. I use mine and have successfully opened them up like 10 times and resealed them with the original glue with 0 leaks and condensation! Its good stuff!
Old Apr 28, 2004 | 01:56 PM
tiguy99's Avatar
tiguy99
Some shots of Valeo ECE:
Mrfouche
Jul 29, 2017 04:02 PM
mckellyb
RX - 1st Gen (1999-2003)
Jun 17, 2014 07:18 AM
Spiziked23
Nov 18, 2012 07:01 PM
kumquatism
Jan 19, 2012 11:55 AM
faithless
Lighting
Sep 9, 2008 11:56 PM
