I am adding auxiliary driving lights to supplement my high beams. They are powered by the battery, via a wiring harness. Where could I tap power from the high beams to trigger the harness relay, so the driving lights would only be lit when the high beams are on?
Thomas in Texas
But I don't see any mention of a high beam relay only a fuse. Have an assistant toggle high beam and listen for a click should be able to locate a relay if there is one. Then you can tap into it. Failing that can always hack into the wiring right at a headlight.
Where are you going to mount the auxiliary light relay?
Sorry for the delay, The auxiliary wiring harness has been mounted under the vanity cover in front of the battery location. I ended up putting a splitter on the high beam wiring and using that to trigger the auxiliary light wiring harness and auxiliary lights.
Thomas in Texas
