Sponsored by: CARiD
Installing Silverstar headlights
Old Nov 17, 2003 | 06:50 AM
vinster29's Avatar
vinster29
Default Installing Silverstar headlights
I bought a pair of Sylvania Silverstar headlights and I'm having some trouble installing them. Can someone give me step by step directions on how to install headlights for an RX300. Thanks
Old Nov 17, 2003 | 07:50 AM
lexusk8's Avatar
lexusk8
Behind each headlight, you should see an electrical connector (with a few visible colored wires) connected to the back of the 9006 stock bulb. Slowly pull the connector out (there might be a plastic tab on the connector you have to press if you're having difficulty), and clean the dirt/dust around the connector if necessary. The back of the bulb should look like the shape of an elbow, and removal of the bulb is done by twisting to unlock (there's only 1 direction). Remember the orientation of the bulb once removed when you start to install the Silverstar bulbs, and then perform the installation from the above-mentioned steps reversed.
It's really plug-and-play, no hardware required, and only takes minutes to finish the job. Hope this helps
Old Nov 17, 2003 | 01:31 PM
vinster29's Avatar
vinster29
Talking Thanks for your help Lexusk8!!
Thanks for your quick reply Lexusk8. After some tinkering and toying with my lights I finally got them in and they are definetely worth the money!! Thanks for all of your help Lexusk8. Your step by step directions were awesome!!! You were a big part of my decision to get these lights!! I couldn't have done it without you.
Old Nov 17, 2003 | 03:28 PM
lexusk8's Avatar
lexusk8
Default Re: Thanks for your help Lexusk8!!
You're welcome vinster29. Glad to be of assistance
Brandon593
Sep 15, 2021 09:36 AM
asmith06
Jul 27, 2016 06:05 PM
palidino
Aug 23, 2013 08:51 AM
Jonathan o
Dec 20, 2007 08:45 AM
AzRxChic06
RX - 1st Gen (1999-2003)
Feb 10, 2005 12:33 AM
