outside mirror motor
Have a problem with me 95 sc300. The outside mirror control does not work. My memory setting on it works on seat only. Can anyone pinpoint the problem?? Fuse OK.
it is located near the steering column, you have to access it by removing the trim underneath the steeing wheel. It is a small white box abour 4"x4", it will say mirror ecu on it.
Hey Alex, You don’t need to remove anything if you don’t want to, just stick your head under the steering column (where the gas and brake are) and you will see the box, it is between the gas pedal and the brake if I remember correctly. Oh yea and I had a very hard time removing my old one so I just gave up and attached the new one right next to the old one. So you don't have to remove the whole thing if you don’t want to. Just make sure that it doesn’t get in the way of your gas or brake pedal.
Tommy
Tommy
lexusguy
Dec 8, 2003 09:10 AM
