Im running into a problem with my 95 sc3, wanted to see if anybody had input
the right front speaker and tweeter have gone out - meaning no sound.
all other speakers sound fine,
before it totally went out, there was a time it seemed like those two speakers were not as loud, and i turned the balance toward the drivers side almost to a 45 degree angle.
I knew that wasnt normal, but ignored it.
now i got no sound from the front component set at all.
if anybody has a solution to this let me know
where is the amp located, if i have to diagnose it ?
First try another speaker in place of the one with the problem. If it works then you know the speaker is bad. Then just buy a pair of new speakers. You can also check the speaker with a ohm meter, should read around 4 ohms I believe. The amp is in the trunk next to the cd changer.
