engine ground wire kit
Old Apr 16, 2003 | 12:18 PM
StrmRdr23's Avatar
StrmRdr23
Default engine ground wire kit
anybody use one of these? does it help? i'm using an alpine amp with my stock head unit (i drive an rx300 w/nak system no nav). i'm getting a lot of engine/alternator noise...per the ads i've seen, these kits should eliminate/reduce that...any opinions on this?
Old Apr 16, 2003 | 07:22 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
ground ... maybe. most likely poor sheilding, cheap rca convertor's do this too, signal wires crossed over power wires, screws through wires (yeah it happens), and the list goes on and on.
there is no reason why you shouldnt be able to cure any noise problems by simply re-doing the install. Alternator noise is not a problem, it is a result of a problem.
Old Apr 17, 2003 | 12:58 AM
theomms's Avatar
theomms
the ground wire upgrade will work to improve the performance of your alternator, but will not help with engine noise.
also if you are a DIY'er just swap the three grounds with 4 guage wire
Old Apr 17, 2003 | 09:12 AM
StrmRdr23's Avatar
StrmRdr23
ok, thanks...i'll try to redo the install to see if there's some stuff that's not right...cheap rca hi-lo converter? can anybody recommend a quality one?
Old Apr 17, 2003 | 09:22 AM
TimDimman's Avatar
TimDimman
If you aren interested in swapping your ground wires, contact TeCKis300, he produces an excellent ground kit.
Tim
JesLet
Nov 5, 2015 08:16 AM
WildCanadi
Apr 11, 2010 11:45 PM
olddog
Jan 2, 2007 10:15 PM
ILOVEGIRLS
Jul 8, 2005 11:56 AM
StrmRdr23
RX - 1st Gen (1999-2003)
Apr 20, 2003 04:08 AM
