Wiring Passage from Engine to Cabin
Old Feb 5, 2003 | 07:30 AM
LexusBiz's Avatar
LexusBiz
Default Wiring Passage from Engine to Cabin
Hey All,
Will attempt to install the (Halo/Angle/Demon/Whatever you want to call them) lights in my SC this weekend. I am running them into a rocker switch mounted in my center console.
Question is what is the easiest or best way to get the wire from the engine bay through to the interior cabin? Is there a passage way in the firewall? I did notice a passage way on the inside driver side fender in the engine compartment. But looks like it will not have access into the cabin.
Any thoughts/ideas greatly appreciated.
Thanks
Biz
92 SC400
Old Feb 5, 2003 | 07:33 AM
Lex Luthor's Avatar
Lex Luthor
Driver side of the firewall, under the master cyl, there's a good size grommet you can use for access...
Old Feb 5, 2003 | 07:51 AM
LexusBiz's Avatar
LexusBiz
Thanks Lex L.
Old Feb 19, 2003 | 12:16 AM
philauldridge's Avatar
philauldridge
Default engine bay/passenger compartment
The other solution is to run your wiring through the main engine harness loom, on the passenger-side firewall. Just remove the screws holding the rubber boot in place, and you'll find a huge hole going right into the passenger well.
Old Feb 19, 2003 | 08:03 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
I prefer a unibit and some silicone.
Old Feb 19, 2003 | 04:03 PM
Camshaft's Avatar
Camshaft
Here is the hole that the wiring harness passes through to the passenger foot well.
Old Feb 19, 2003 | 05:43 PM
nextlevelcoupe's Avatar
nextlevelcoupe
is this install for a sc? and if so,how are u going to custom it to your headlights?
Old Feb 20, 2003 | 09:40 AM
LexusBiz's Avatar
LexusBiz
Philauldridge/Camshaft,
Thanks for the helpful info and pictures.
Nextlevelcoupe,
Going to attempt to place the halo lights in my SC4 main (lowbeam) headlights. I have the halo's made and just need a good weekend to take apart the headlight assembly.
My car does not have heated seats, so I am taking out the spare plastic filler piece and installing a rocker switch to be able to control the halo lights from within the cabin and not through the parking lights.
I was attempting to get the wiring through the engine bay into the cabin, but could not find any openings until the forum members came to the rescue and showed me how to get through.
Thanks All
Biz
Old Feb 20, 2003 | 05:08 PM
hiyabrad's Avatar
hiyabrad
Can you tell us how you made the halo's and do you have pics?
Old Feb 21, 2003 | 04:27 AM
LexusBiz's Avatar
LexusBiz
Hey Hiyabrad,
My digital camera crapped out on me. I am attempting to borrow another one from a friend. As soon as I get pics I will put together a little document with the steps I took building/installing the halo.
I plan on tackling the project next weekend hopefully. I will post pics hopefully then.
THanks
Biz
Old Feb 23, 2003 | 09:46 PM
hiyabrad's Avatar
hiyabrad
Excellent!
Old Apr 3, 2006 | 11:21 AM
reddlexus's Avatar
reddlexus
Default Pics!!!
Could someone please post pics of where exactly to run wire from engine to inside of cabin on drivers side? Thanks!!!
Old Apr 3, 2006 | 11:38 AM
VJ RC51's Avatar
VJ RC51
yup thats the one i use for everything
Old May 11, 2006 | 07:46 AM
reddlexus's Avatar
reddlexus
Where would you drill the hole? Thanks!
yauny
Jul 29, 2015 10:27 AM
jkpgt96
Jul 16, 2015 08:01 AM
DvSiR
Jan 13, 2010 12:51 AM
el maestro
May 19, 2009 02:50 PM
