Which free air sub?.
Old Jan 2, 2013 | 12:52 PM
chubz's Avatar
chubz
sorry to bring this back from the dead but im going to do an aftermarket setup in my 2gs. i already have the head unit, jdm dash kit and jumper harness along with little alpine im going to run since they say once you switch to an aftermarket radio the factory amp and sub wont work anymore. i also want to keep all my trunk space so im going with a sub to fit in the factory spot on the deck. im not looking for crazy bass, just stock sounding or alittle better. how is the kicker comp10 for this application?
Old Jan 15, 2013 | 06:15 AM
chubz's Avatar
chubz
anybody???
Old Jan 15, 2013 | 06:48 AM
maxx430's Avatar
maxx430
I have an IDQ10 in the place of the stock sub. it fits just fine with a few mods to mount the sub. it sounds better than the stock sub. however it does not hit as hard as a sub that is enclosed in a box. its more for the sound of bass and not the feel. i am powering it with a 250rms alpine. to be honest, in the driver seat, i dont even hear much of the sub. i hear my front speakers more.
Old Jan 16, 2013 | 09:24 AM
Robert_J's Avatar
Robert_J
Any sub with a decent amount of travel (16mm or more xmax), medium to high Fs (28 to 40hz) and a Qts of of .600 or higher will work. I like a a little more bass so I choose subs with a lower Fs (about 25hz) and a lower Qts (around .500). Both AE Speakers and Fi Car Audio make infinite baffle subs that meet the specs I listed.
Old Jan 23, 2013 | 10:13 AM
Tank's Avatar
Tank
I used a Fosgate 10 inch fit right into the old sub hole with very minor modification. built a box around it and bolted it up to the rear deck but I have a 2nd gen GS don't know how well it would work for a SC, and for the record your stock sub will work as long as you wire it directly to the radio (if it has that option for a sub)
Old Jan 23, 2013 | 03:39 PM
maxx430's Avatar
maxx430
^ interesting. can you snap a picture of the box you built around the sub? i was thinking about that for my sub but couldnt decided how to built the box.
Old Jan 23, 2013 | 11:54 PM
lostthumb's Avatar
lostthumb
You can fit a 12" if you make a spacer like the one on this page. I did something similar and mounted an Image Dynamics IDQ12v2. Sounds great.
https://www.clublexus.com/forums/gs-...-location.html
Old Jan 24, 2013 | 05:49 AM
chubz's Avatar
chubz
i didnt want to go crazy with this setup. i did my setup this past weekend with a few friends. came out great. i went with the kicker comp 10 on the deck and a nice alpine amp with a kenwood touch screen. (mixed brands lol) sounds great though. alot more bass than factory and sounds alot clearer. im very happy with my choice and i get to keep all my trunk space!
Old Jan 29, 2013 | 02:51 PM
Tank's Avatar
Tank
Here you go..
Attached Thumbnails Which free air sub?.-2013-01-26_10-18-43_151.jpg   Which free air sub?.-2013-01-26_10-18-57_475.jpg   Which free air sub?.-2013-01-26_10-20-41_43.jpg   Which free air sub?.-2013-01-26_10-19-20_453.jpg
Old Jan 29, 2013 | 04:58 PM
maxx430's Avatar
maxx430
cool. that a is very unique concept. and it fits right above the bar.
Old Feb 18, 2013 | 07:31 PM
Tank's Avatar
Tank
Thank you sir..
Old May 19, 2013 | 11:35 AM
Smartazz91's Avatar
Smartazz91
Default Aftermarket sub in an SC
Robert J,
First, thanks for all the knowledge you've contributed to the forum. Have you ever modeled the ED SQ10 for IB use? I've searched but couldn't find anything specific. I have a 93 SC and I'd prefer to replace the stock sub as opposed to putting a box to the trunk. From what I've seen, the SQ10 is a great fit with almost no modification but does it work? I know the company is gone but I found someone online who's selling one. It will be powered by an aftermarket amp. I have a different ED (11OV2, I believe) sub running IB in my 2GS with about 400 watts and it sounds great. That same sub, if I could even find it, wouldn't likely clear the SC's gas tank. Unfortunately, I can't find the specs on the SQ10. Any help would be greatly appreciated.
Old May 21, 2013 | 10:02 AM
Robert_J's Avatar
Robert_J
I replied to your IM with the T/S parameters of the SQ10. If that deal falls through, the Tang Band shallow sub is very, very similar (a clone?) to the SQ10 - http://www.parts-express.com/pe/show...number=264-862
Another option is the MB Quart 10" shallow sub - http://www.techronics.com/caraudio_1...Subwoofer.html A family member has a pair of these installed in a truck and raves about the sound.
Old May 26, 2013 | 05:48 PM
Smartazz91's Avatar
Smartazz91
Default SQ10 Infinite Baffle
Thanks for getting back to me in both the thread and PM. This brand new 2 ohm SQ10 was $55 shipped from an ebay seller, so I jumped on it. I realize there won't be any support if I the sub fails but I'm okay taking that chance. I'm balancing SQ, budget and ease of install so if the SQ10 meets my needs, I'm a winner. If not, I'll go with the whatever else YOU think will work. Based on T/S parameters, should the MB Quart be a better performer in IB than the SQ10? Considering how small an enclosure the SQ10 calls for, it may end up in the tool tray of my RX330, which is in desperate need of some low end.
Thanks again
Old May 28, 2013 | 06:53 AM
Robert_J's Avatar
Robert_J
Based on T/S parameters alone, they should perform very close to each other. But parameters are never the last word in subs. You have the SQ10 so run it. If it does fail, there are other subs that can drop right in.
ZippyGuy
May 9, 2017 06:54 AM
swood1001
Feb 1, 2013 12:01 AM
junkyardje
Mar 27, 2008 04:56 AM
mikepae
Sep 7, 2006 12:26 PM
Sexlexo69
Jan 9, 2002 06:19 PM
