hole in subwoofer. Can it be repaired?
Old Aug 23, 2011 | 04:30 PM
appraiser's Avatar
appraiser
Default hole in subwoofer. Can it be repaired?
Subwoofer box tipped over and hit the corner of the box.Therre is now a hole in Cone. Speaker still sounds good however is there anyway we can patch that hole and not compromise the sound?? I do not want to replace entire sub speaker.
Old Aug 23, 2011 | 10:29 PM
Debonair's Avatar
Debonair
Yes, the speaker can be repaired. How big of a hole is it? Is the material from the hole still attached or detached or lost? Of course a picture is worth a thousand words.
Old Aug 23, 2011 | 10:45 PM
1sWt2GS's Avatar
1sWt2GS
SUPER CHEAP fix would be silicon.
Old Aug 24, 2011 | 04:42 AM
Robert_J's Avatar
Robert_J
As said earlier, a picture of the hole and the sub manufacturer/model make a huge difference in how we approach this.
Old Aug 26, 2011 | 12:10 AM
appraiser's Avatar
appraiser
Will get photos and upload for review.
Old Sep 15, 2011 | 07:14 AM
appraiser's Avatar
appraiser
Attached are the photos. Any suggestion in how to repair?
Attached Thumbnails hole in subwoofer. Can it be repaired?-img_1555.jpg   hole in subwoofer. Can it be repaired?-img_1554.jpg
Old Sep 15, 2011 | 07:16 AM
appraiser's Avatar
appraiser
Attached are the photos of my torn Woofer Cone. Any suggestion in how to repair? Quick fix. Do not really care what it looks like now.
Attached Thumbnails hole in subwoofer. Can it be repaired?-img_1554.jpg   hole in subwoofer. Can it be repaired?-img_1555.jpg
Old Sep 15, 2011 | 08:37 AM
Robert_J's Avatar
Robert_J
The hole in the dust cap is a non-issue unless it goes all the way through the cone.
On the rubber surrount, silicone or Plumber's Goop (my favorite) will work. Patch it from the back side so it doesn't look bad. Use a rubber glove to keep from getting sticky stuff all over your hand.
Old Sep 15, 2011 | 10:55 AM
GR6RR's Avatar
GR6RR
+2 on the silicone. I've repaired three different brands and size of subs with this magical silicone.
Old Sep 15, 2011 | 02:32 PM
Robert_J's Avatar
Robert_J
Silicone and Goop type products only work on rubber surrounds. Foam and neoprene will sometimes melt when touched by those substances. In that case you would need a latex caulk. DAP makes some good ones.
Old Jan 16, 2012 | 07:31 AM
appraiser's Avatar
appraiser
Could I use rubber cement?/
Old Jan 29, 2012 | 06:05 PM
appraiser's Avatar
appraiser
How do I fix the paper cone?
I have not had time to address this. Can I also use Heavy duty duct tape?
Old Jan 30, 2012 | 09:15 AM
Robert_J's Avatar
Robert_J
Post a picture from the back side of the cone.
I'd probably try to position the torn pieces together and use CA glue (aka super glue).
Old Feb 1, 2012 | 04:16 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Permatex makes the best sealer due to it's malleability and after all......... it "IS" gasket maker.
Old Dec 21, 2020 | 05:02 PM
Dream18's Avatar
Dream18
Default Huge whole in cone
I have a huge hole in my cone what can I use to repair it
rhwimmers
Aug 11, 2019 03:10 PM
alanchad
Sep 18, 2009 06:24 AM
handzilla
Jul 11, 2006 06:08 AM
Static911
Nov 27, 2001 10:20 AM
