quick qestion
Old Jan 4, 2011 | 07:47 PM
kpkim01's Avatar
kpkim01
Default quick qestion
whats up guys, ive been researching online for thi and around CL too but havnt really found a straight forward answer that me (a newb) could really understand.
so the question is basically, if i connect 2 subwoofers to lets a an 800 watt amp, are both subs goin to get 800 watts or will they get 400 each?
Old Jan 4, 2011 | 10:15 PM
rayy117's Avatar
rayy117
depends on the specs,brand, mono, two channel
Old Jan 4, 2011 | 10:33 PM
kpkim01's Avatar
kpkim01
Just in general like a mono 800 watt 400rms
Old Jan 4, 2011 | 10:58 PM
rayy117's Avatar
rayy117
if its a mono, it'll be 800rms depending on the brand....if its 2 channel 800 watt... it doesnt push exactly 400.... it might be lower
Old Jan 5, 2011 | 12:36 AM
Jace_91's Avatar
Jace_91
the only reason you haven't found a straightforward answer is that there really isn't one, these questions vary greatly depending on the amp. I would look at the research section of crutchfield.com they have a lot of good info on amps
Old Jan 5, 2011 | 05:16 PM
Big Mack's Avatar
Big Mack
Cool
Incorrect. The amp does not matter - the ohm values do, but only if they are different.
In mono, both subs wired to the amp, they will split the power evenly between them - provided they are the same ohm value (typically 4 ohms each per coil, but check your specific sub for more info). This is true of series or parallel wiring. If there are different values, the one with the lower value would get more power than the other.
Big Mack
Old Jan 6, 2011 | 10:10 AM
adreano17's Avatar
adreano17
whats the amp make and model so we can give you a straight forward answer.
Old Jan 27, 2011 | 11:26 PM
xsh0tya's Avatar
xsh0tya
Big Mack
Correct and Incorrect BigMack... I might got you on this one. Mack is def right. But some amps such as JBL Crown amps have a patent technology... ie some crazy magical powers.... where they push 1000 watts (not exact specs) no matter what the ohm value or so they state. Correct me if im wrong folks.
Old Jan 28, 2011 | 07:07 PM
Big Mack's Avatar
Big Mack
Cool
What's incorrect? It's Ohm's law - less resistance = more power in any circuit. This is not going to change. The total load isn't the issue. The components of the load are, and that's where it divides.
JBL isn't the only one that does the same power into any load between 1 & 4 ohms. JL Audio has been doing this for years. They change the rail voltage inside to keep the power level constant.
Big Mack
Old Jan 28, 2011 | 07:38 PM
xsh0tya's Avatar
xsh0tya
Big Mack
Lol I knew it you got me again Mack .... ONE DAY !!!!
Old Jan 28, 2011 | 07:51 PM
Big Mack's Avatar
Big Mack
Cool
I do what I can, mang. I do what I can.
Big Mack
Old Jan 29, 2011 | 05:15 PM
Percy's Avatar
Percy
Moderator - Electronics Forum
25 Year Member
Big Mack does good work. Nothing like practical "in the sound bays" experience.
I always enjoy the show.
Old Jan 29, 2011 | 11:56 PM
xsh0tya's Avatar
xsh0tya
I know... Mack def knows his stuff... thats why when you try and come at someone like him chose your words carefully... if you dont wanna look silly. I have been on the sales side of car audio for years, but only learned what things can do not so much knowledge as to really why or how.
Old Jan 30, 2011 | 12:11 AM
Big Mack's Avatar
Big Mack
Cool
Thanks, mang. I try to keep it fun at the same time.
And thanks to you, too, mang. I like helping out where I can, and I am also very careful to not put out something wrong - don't want anyone letting out the magic smoke, right?
If you do sales, I would strongly encourage you to learn the why/how. It gives you more opportunity to explain why an upgrade might serve a customer better in the long term. Better they spend an extra 5-10% now than 70% more again when they want to do something mo bigga/betta. It also teaches you how to ask better questions when you know the other options that might be possible.
Big Mack
Old Jan 30, 2011 | 12:36 AM
xsh0tya's Avatar
xsh0tya
Big Mack
Absolutely I should have said that I USED to do sales but I def agree with you. I do have more knowledge that the average joe when it comes to car audio but what I didnt know is how those JBL amps put out that wattage at whatever given load... now Im in a whole different line of work.. I switched to the medical world, so now its just a hobby rather than a career but I def appreciate you sharing some of that magic with me.
chippern73
Jun 18, 2010 05:36 PM
mcnelson
Oct 28, 2003 02:44 PM
tommie
Mar 30, 2003 05:30 PM
