subs stopped working?
So the other night i was driving home from playin poker and my subs just stopped working. The light on the amp turns green then like 2 secons later turns red. I have checked all fuses and connections everythings good no idea what the problem could be? maybe i over heated the amp? any ideas please let me know!
I'd suggest checking the internal connections to the sub(s) and making sure you didn't fry them. You can also check the DCR if you have a meter, just be aware that a sub's DCR will NOT be the same as it's nominal load. If you see 3.8 ohms for a 4 ohm speaker, that should be fine for a "typical" sub. If they're wired in parallel to show a 2 ohm load and you only see 0.5, though, something's definitely wrong.
Oh yeah, and Scooter's right, fuses can look good and still be bad, but it doesn't sound like a voltage issue to me.
Big Mack
the ground and power connections and subs are fine i hooked my other 1000 watt amp out of my deville to test the subs and everything works, ill try to replace the fuses and see what happens.
noyz25
05-25-11 04:04 PM
TIKTIK11
02-05-02 09:47 PM
