help... (installing double din)
Old Nov 28, 2008 | 05:12 PM
jdub20tx's Avatar
jdub20tx
I'd like to get one of those from you if youre interested in selling one... Im in Garland Where in Tx are you?
Old Nov 28, 2008 | 09:26 PM
RedPhoenix's Avatar
RedPhoenix
Originally Posted by rich001
Metra will be coming out with a double DIN stereo kit for the 92-00 SC300/400 in a few weeks. The part number will be 95-8157B for the double DIN kit and for the single DIN kit... 99-8157B. Possibly by mid December.
Is this confirmed?
Old Nov 29, 2008 | 08:32 AM
BSC300TT's Avatar
BSC300TT
I personally haven't seen it but it doesnt mean its not coming. I personally wanted mine to look stock and not like a piece of plastic snapped together.
Old Dec 28, 2008 | 02:24 AM
Jfg kevin's Avatar
Jfg kevin
Old Jan 29, 2009 | 12:11 AM
Bigb0i_SC4's Avatar
Bigb0i_SC4
what do u think is the best way to connect the speakers to the aftermarket head unit run new wires or reroute the exsiting ones.
Old Feb 3, 2009 | 06:52 AM
mcwop23's Avatar
mcwop23
what about this install kit? http://shop.beatsonicusa.com/product...=2&productId=4
Old Feb 9, 2009 | 06:32 PM
durtysc300's Avatar
durtysc300
i know for a fact metra makes a double din kit for the sc3/4 i just ordered a single din kit for my car the actual putting the unit it won't be the hard part..its the wiring thats going to suck.
Old Feb 9, 2009 | 09:02 PM
phrozen's Avatar
phrozen
Wiring is not bad at all... here are the steps.
Remove pass side running board and kick pane
remove rear seat cushion by lifting up
remove 3 10mm to remove upper seat portion
remove the pass side trunk trim
remove cd changer
remove factory amp and disconnect
take the output side plug cut off the end.
using "speed wire" u can purchase from ur local audio shop or bestbuy hook up the wire from the amp to the speed wire and run that up to the radio cavity and continue wiring ur radio as usual. power/switched/ground/power antenna can all be grabbed from the radio cavity.
TRACKMKIII
GS - 1st Gen (1993-1997)
17
Jan 7, 2025 11:52 AM
LiLS
Jun 8, 2009 05:30 PM
Tymboo
May 25, 2007 11:38 AM
carrli
Jun 29, 2006 06:26 PM
