Sc300 audio questions
Old Jul 20, 2008 | 10:50 AM
uhohyo's Avatar
uhohyo
Default Sc300 audio questions
Thanks for the help guys.
Old Jul 20, 2008 | 02:30 PM
uhohyo's Avatar
uhohyo
Any ideas?
Old Jul 20, 2008 | 04:09 PM
captainsc's Avatar
captainsc
Ok the CD changer is one of the most common problems SC owners have. I my self had it too and it can be annoying. I was told to run a CD cleaner through each disc slot to possibly help. Personally I never tried it, I had already bought a whole new system, but it would only cost you $10 and it's worth a shot. The speakers could be three things. They most likely are blown or just deteriorated due to the age. Also remove the rear trunk lining and check your connections. If all of these things are not the problem you might have an amp problem which can also happen. All of these parts can be found online but do cost a little more than most would like. Hope this helps and good luck with your system.
Old Jul 20, 2008 | 05:36 PM
5sp_jzz30's Avatar
5sp_jzz30
you sir need to use the search button. every single topic that you are wondering about has been covered extensively.
not trying to be an ***. simply saying that the search button is your best friend.
Bati
GX - 1st Gen (2003-2009)
May 23, 2012 09:21 PM
j stuff
Nov 17, 2010 04:57 AM
Woogie
Aug 18, 2005 02:13 AM
wSC300
Aug 11, 2005 07:42 AM
pp0323
Jan 3, 2003 12:44 AM
