Wiring extra sub into trunk
Old Jan 24, 2002 | 09:36 AM
moshlub's Avatar
moshlub
One of my friends took his car (not a Lexus) to the Good Guys around here. He had a CD-deck, EQ, active crossover, two amps, and two subs. They didn't hook up the crossover and didn't bolt down the amps. When he took it back, they said they didn't see the crossover and thought that he didn't want the amp bolted down. After they hooked up the rest of the equipment and bolted it all down, they scratched his window tint. Can I say quality service???
Old Jan 24, 2002 | 10:47 AM
933005spd's Avatar
933005spd
Post my 2c
No speaker adapter is needed. The inputs to the circut board are RCA from the head unit wire direct to a rca male plug.
The power cable is not that difficult to run, you do not need to run a remote or inputs since you can tap these from the sub amp or the NAK amp depending on which you have.
Old Jan 24, 2002 | 11:12 AM
SupraCoup3's Avatar
SupraCoup3
I will -- I'm heading over to my local lexus dealership, might be getting a job there. That would be fun... I'll tell you how that turns out too!
Old Jan 24, 2002 | 02:51 PM
SupraCoup3's Avatar
SupraCoup3
it's the MTX 4250D amp... well I guess anyone need an RCA converter? I'll sell it and ship it (still in the box) for 20 bucks.... As long as I'm sure i don't need it
Old Jan 31, 2004 | 11:01 PM
96sc3's Avatar
96sc3
so if i change the stock amp and the stock sub will i be able to control the base from the pioneer stock head unit?
Old Jan 31, 2004 | 11:45 PM
howiedoit's Avatar
howiedoit
yes
Old Feb 1, 2004 | 06:00 PM
96sc3's Avatar
96sc3
thanks, how about if i just add another sub to my stock pioneer radio with the stock sub? is it a good idea?,.,. is the stock amp running only the sub or the speakers too? if it is how many watts is it running?
Old Mar 4, 2004 | 03:40 PM
aromack's Avatar
aromack
Default amp or not a amp?
what is the device under the stock 12 disc changer in the 95 sc400? It looks like an amp but I am not sure it is or not.
Old Mar 4, 2004 | 08:55 PM
no2faber's Avatar
no2faber
yup that's the amp.
Old Mar 5, 2004 | 08:23 PM
mikenglv's Avatar
mikenglv
i dont recommend keeping the stock 10, you should take it out and leave the whole empty and open as a port hole, trust me it makes the car alot louder, i just put in 2 12" eclipse, the port hole made the noise much cleaner and the bass cleaner.
mbbng
Aug 8, 2014 07:07 AM
Frankdorn
May 28, 2010 10:26 AM
danger4o5
Feb 25, 2008 01:06 AM
kmn5
Feb 16, 2006 09:01 PM
vicestan
May 24, 2005 10:06 AM
