Installing sound system
Old Nov 26, 2007 | 04:08 PM
UncleRay's Avatar
UncleRay
Default Installing sound system
Alright, after Tantra and I routed the wiring for the amp, I'm left hopeless!!! How , and where do I attach the RCA, and remote wire to? I already have the ground, speaker, and power cable set up. All is left is the RCA and the remote wire.
GS 400 1999 with factory head unit.
Old Nov 26, 2007 | 04:15 PM
DJ TANTRA's Avatar
DJ TANTRA
I told you a few times..but maybe it'll help if it is written...
The RCA obviously goes into the AMP input...
and the Remote wire...Did you get the fuse accessory?
That fuse accessory you can plug in to go with your heated seats...or you can plug it in to go with something else..your choice...
Or for the antenna you can take apart your dash and link it with your factory remote connection..
Old Nov 26, 2007 | 04:25 PM
UncleRay's Avatar
UncleRay
Won't that just kill my electrical system? And then where do I install the RCA cables into my radio??
Oh and btw, that Hi-Low you gave me, IS BROKEN.
Old Nov 26, 2007 | 09:09 PM
DJ TANTRA's Avatar
DJ TANTRA
how is it broken?
And RCA GOES INTO YOUR AMP!
and I dono man...I think the electrical systems in my car aree workin..it's simply telling the amp wen to turn on..
Old Nov 27, 2007 | 06:37 AM
UncleRay's Avatar
UncleRay
Some of the wires for the high low disconnected from the main circuit board.
Old Nov 27, 2007 | 10:14 AM
DJ TANTRA's Avatar
DJ TANTRA
it wasnt broken when I gave it to you..
any audio store should have it...it will cost around 20/30 bucks.
I think best buy has it as well
Old Nov 27, 2007 | 08:57 PM
UncleRay's Avatar
UncleRay
Okay! I got the mini fuse, and a brand new high low. Installed the remote wire to the fuse just like you said, and the high low was obvious. New problem! The amp doesn't turn on!!
What now tantra? HMMMM?
Old Nov 27, 2007 | 09:11 PM
PK_Celsior's Avatar
PK_Celsior
you might of tapped the wrong rem wire
a trick you can do to see if the amp is really dead is take a lil wire and touch it with the rem and positive power
if it turns on the amp is fine if it doesnt it fried some how
Old Nov 27, 2007 | 10:45 PM
UncleRay's Avatar
UncleRay
the amp isn't dead. I tried it on a friends car, and it worked.
Old Nov 27, 2007 | 11:12 PM
DJ TANTRA's Avatar
DJ TANTRA
yeah, that is how you can test it.
If your amp is not getting signal, it can be that you didnt ground it properly...or check the power wire again...
if those two are good to go...then it is something with you ant...and its not turning your remote on..
you gotta recheck the connections!
does the amp have a LED that signals it turning on?
Old Nov 27, 2007 | 11:23 PM
UncleRay's Avatar
UncleRay
I'll check all of the wiring this thursday. Only day when I'm free!!! Tantra, my place this time?
The AMP does have an LED indicator.
RAMAIR
Nov 26, 2022 11:18 AM
Sheehan1p
Jan 15, 2010 03:42 PM
Sc2jzge300
15
Feb 26, 2005 02:15 PM
kyle8744
13
Jul 23, 2004 09:00 AM
sxwk12
Jun 13, 2003 12:57 AM
