good replacement for 10" subwoofer ?
Old Aug 22, 2007 | 05:10 PM
Eggman's Avatar
Eggman
Default good replacement for 10" subwoofer ?
i need more bass. but i dont want to change out my headunit or add an amp. i just want it simple. anyone have suggestions for a 10 inch sub that will nicely replace my stock one?
i dont know jack about stereos. i did some searching and a few people bought pioneers. but what model? the ohms confuse me. so is there a good direct replacement?
Old Aug 22, 2007 | 05:23 PM
iasc300's Avatar
iasc300
Try the Lexus Audio, Video, Security & Electronics forum
Old Aug 22, 2007 | 05:37 PM
JspecSC3's Avatar
JspecSC3
There are plenty of stock replacements. When choosing the right subwoofer you want to make sure that it will clear the top of the gas tank. Also, everytime the bass hits so will the subwoofer cover. Thats why I would just get a small box and leave it in the trunk if you want to keep it simple.
Old Aug 22, 2007 | 06:00 PM
CCC-TT's Avatar
CCC-TT
i talked to a few car audio shops about this and they said they can do it with a decent sub, but you will need a new amp for the power, otherwise it wont really hit any harder
Old Aug 22, 2007 | 10:20 PM
Eggman's Avatar
Eggman
i just want it to hit a bit harder. not too much more.
Old Aug 23, 2007 | 12:05 AM
Eggman's Avatar
Eggman
well i was hoping to hear from other SC owners. to get more of a specific application recommendation. :P
Old Aug 23, 2007 | 08:51 AM
Robert_J's Avatar
Robert_J
By "hit harder" do you want more extension (lower notes on the scale), more volume (LOUDER!!!!) or both? Just replacing the sub may make things worse though. Bass (both volume and extension) require the sub to move air. There are hundreds of subs on the market that will move more air than your factory sub but these subs have a lower sensitivity. That means it takes more power (wattage) to reach the same volume as your current sub. There are subs with higher sensitivity but those usually don't have the extension of your current sub. In the sub world, it's all a trade-off. Unless you know the details of your sub, then it is a gamble with the outcome when you switch subs.
If you are willing to go with an additional sub amp, then we can recommend dozens of replacements. If you can build an adapter and use a 12" sub since then we can help as well. If you don't want an amp or the hassle of a 12" sub, then I recommend that you don't do anything.
-Robert
vital
Mar 17, 2017 02:44 AM
shabbir1
Dec 25, 2013 02:42 PM
Devor
Nov 17, 2012 02:25 PM
kevin.tran
Jul 14, 2010 06:18 AM
huNGjaii
Mar 2, 2009 12:07 PM
