one more question...
Old May 17, 2007 | 08:52 PM
kingomar's Avatar
kingomar
Default one more question...
hey there. i have a 4 speaker system being powered by an alpine pdx 4.150. there is a switch for "input channel selector". there are three settings. (listed as they are in the manual):
a) Setting this switch to “1 + 3/ 2 + 4” will sum the CH-1 and CH-3 input and send it to CH-3 while the CH-2 and CH-4 inputs are summed and sent to CH-4.
b) Set this switch to “3/4” to have the inputs of CH-3/4 accept independent input signals. An example of this application would be the use of a head unit with dual pre-amp outputs.
c) Setting this switch to “1/2” will send the signal at the inputs of CH-1/2 to CH-3/4 of the PDX-4.150. This eliminates the need for
“Y”-adaptors when using a head unit with a single pair of pre-amp output.
there are 4 rca cables coming out of the headunit (two for the front and 2 for the rear). right now channel 1 is front left; channel 3 is rear left; channel 2 is front right; and channel 4 is rear right.
im not sure which of the three above settings i should use. any suggestions?
thanks again guys
Old May 17, 2007 | 09:11 PM
88supramki's Avatar
88supramki
set it however you need to make it a full 4 channel amplifier, especially since you have 3 rca preouts on the eclipse unit. then just run the rcas to front and rear rca outputs
Old May 17, 2007 | 09:15 PM
kingomar's Avatar
kingomar
well, all 4 speakers work with any of the three options. however, i was thinking that option b might be the best since im only using 2 of the 3 preouts on the eclipse.
t.is350.h
Aug 20, 2009 10:19 AM
vwynn
Maintenance
Mar 18, 2009 09:28 AM
VVTIS
Jun 6, 2003 02:36 AM
whitels
Jul 20, 2002 06:57 PM
