Rear speakers
Old Oct 11, 2004 | 01:35 PM
RSS4665's Avatar
RSS4665
Default Rear speakers
I recently purchased a 92 SC400 and the Nakamichi stereo and the 12 CD changer were replaced about a year ago by the local dealer (every service was done by Hennessy Lexus!), but the rear speakers and the subwoofer do not work. So...
1. Do you HAVE TO remove the rear seat to access the speakers?
2. Is there any way of determining if it's the speakers and not the amplifier?
3. What exactly is the replacement size for the rear speakers?
4. Has anyone had them replaced by any of the big stores ( Best Buy, Circuit City, HiFi Buys?)
Thanks for ANY input!
Old Oct 11, 2004 | 01:43 PM
bizzy928's Avatar
bizzy928
Default Re: Rear speakers
1) Yes, you need to remove the rear bench first, then unbolt the rear seat backing. Then you can remove the rear deck carpeting
2) Hook up your new speakers to the amp, if they don't work its the amp.
3) I replaced mine a while ago... I think 3 1/2 inches
4) Yes, I got some RCA replacements from Future Shop (Best Buy Equiv).
Old Oct 11, 2004 | 01:52 PM
mikeloc24's Avatar
mikeloc24
That's funny, all my rears have been replaced and the rear seat was never removed, we just went in through the trunk and worked there and above the rear parcel shelf, no removal of the rear seats was necessary. I have a 92 SC by the way. Here's a link that shows speaker sizes: http://www.walmart.com/promos/stereo/Lexus.pdf
I would never let Good Guys, Circuit City, or any of those places touch my car. I've had bad experiences with them and their techs are usually underpaid and lacking technical installation savvy, not a good combo. Just to give you a quick answer the rear speakers on your car are 4's with a 10 inch sub in the middle. I have read about individuals who were able to squeeze 6 1/2's into the rear parcel shelf, just requires a little cutting. As always use the "SEARCH" function and you'll find answers quickly and in abundance
Old Oct 11, 2004 | 02:17 PM
AutoCoutureSC's Avatar
AutoCoutureSC
on my car, fronts are 4"
rears are 5.25 w/ 10" woofer
Old Oct 12, 2004 | 05:00 AM
jcm3's Avatar
jcm3
Cant see you to remove the rear speakers w/o taking the rear parcel shelf off. In order to take the raer parcel shelf off you need to take the rear seat out (there 2 push plugs that hold the parcel on thats located behind the top of the rear seatback). 5.25 in the rears fit perfectly.
Old Oct 12, 2004 | 07:10 AM
TeeDub's Avatar
TeeDub
Are you sure... What about just pulling out the lining in the trunk that is held on with 4 little metal clips?
Or is that just the easy way to get to the sub and gas tank?
Old Oct 12, 2004 | 07:22 AM
jcm3's Avatar
jcm3
The mounting bolts are located on the top of the parcel shelf not on the bottom. Pulling out the liner get you access to the bottom of the speakers and the gas tank.
Old Oct 12, 2004 | 07:58 AM
T0ked's Avatar
T0ked
The speakers are 4" all around (front doors and the rear deck fills). In the rears, the speakers sit in little pods that raise them up about 1.5-2". If you get rid of those, you can fit bigger speakers. I replaced the OEM speakers with a pair of 6.5" Boston Pros into the pods by boring out the hole. Another option is to mount them directly into the deck but that might require some cutting of sheetmetal.
If you just want to replace the speakers, they are 4" and most will pop right in. Please get a decent pair of speakers, and not just the $49.99 special from BestBuy.
The NAK sub is a 10" freeair and is rated for 5 Ohm. The Pioneer in the premium stereo is a 10" also, but is 1 Ohm, so they are not interchangeable. The NAK subs pop up on ebay every now and then, so I would start there.
Old Oct 14, 2004 | 01:02 PM
THE_CEO's Avatar
THE_CEO
100% correct i just replaced everything except the tweeters!
CEO
WICKED SC4
Nov 3, 2008 11:04 AM
icgraven
Apr 10, 2004 02:08 PM
dbullen
Aug 27, 2003 11:06 AM
amati5
Nov 19, 2001 10:15 AM
