subs
Old Aug 16, 2004 | 01:51 AM
will33184's Avatar
will33184
it will be awesome with 1 1000/1 on 1 13w7
no offense at all to dagr8, but you will NOT blow the 13w7 with a 1000/1
there is almost no way in hell u can do that regularly.
the only way u can blow a 13w7 with that amount of power is if you clip the amp.
the key is install.
make sure you go to a pro-audio shop
running that amount of power u WILL need to run 0-gague or triple 4
you should do "the big 3" on your car's system
you should get a optima yellow top battery
you should fuse your wires at least 18" or shorter from the battery, then whenever u change wire sizes, fuse again (usually before the amp).
dont leave any metal parts exposed to where they can be touched by water
make sure you just take it to a very reputable store. al&eds at least.
make sure you buy it from a dealer
JL has one of the BEST warrantys NOT one of the worst, while it is true they take time to repair your unit, if it is indeed a defect, they will replace it.
im a car audio fanatic, i've do alot of local cars and change my setup every 2 weeks or so.
if you have any questions, ask me any time at wjcheng@ucla.edu
btw, i think you will want to try RE subs.
but the w7 is a awesome choice
peace
Old Aug 16, 2004 | 09:01 PM
Gs Dreams's Avatar
Gs Dreams
Default subs
thanks for the input im just trying to get the best set up and the best system for the best car (gs of course)any input on componets and amps for them
Old Aug 18, 2004 | 03:57 AM
04GS300's Avatar
04GS300
I'm not a boom guy but I love Image Dynamics. I decided against JL because I was told their foam surrounds would deteriorate a lot faster than rubber. I don't know but most people use rubber so why take the chance. A lot of people love JL though...but I vote ID!
Old Aug 18, 2004 | 08:25 AM
Lexis11's Avatar
Lexis11
I love JL all of their lineup is very nice. I have a 300/4 running my xr650.csi and xr650.cxi. They sound so clean and nice, I also have a 500/1 running a 210w6 box. The whole system just sounds clean not too much boom but just enough. I tried the w7 just too much boom for me but they are awesome dont get me wrong. Either way you go the 13.5 and 1000/1 is a great setup.
Sheehan1p
14
Feb 24, 2010 05:44 AM
ByoungWoo
Feb 21, 2008 07:49 PM
Sw33tIS300gyrl
IS - 1st Gen (2001-2005)
Jun 9, 2002 02:53 PM
Mean Gene
Sep 2, 2001 05:59 PM
sirsomo
Jun 30, 2001 12:45 PM
