JDM amp question
Old May 13, 2004 | 08:38 PM
jrmoskal's Avatar
jrmoskal
Default JDM amp question
Is anyone here familiar with the amp from the JDM Soarer. I purchased a used in dash CD and new amp from a JDM Soarer and it works great other than the amp is much larger than the factory Pioneer unit. Does anyone know the power or the exact difference between the two amps. Everything plugs in exactly the same but the JDM amp and headunit are made by Panasonic instead of Pioneer. The only problem I am having is that there is so much more distortion at high volume with this new setup. It seems like the old amp had some sort of crossover built in to filter low freq's from the mids and now the mids are trying to produce deep bass with the sub and distoring badly. Any suggestions on how to correct this.
Also the sub seems to stop working when the volume is turned past 12' oclock position. It hits good at low volume but when the sound is turned up the mids/ highs get louder but the sub stays the same.
jeremyp
Aug 23, 2011 10:41 AM
kuziwk
Jul 11, 2010 09:45 PM
gmac1337
May 30, 2006 10:43 PM
bezee
Aug 7, 2005 06:23 PM
XxLS400xX
May 1, 2003 06:25 PM
