Help with line out converter
Old Oct 7, 2025 | 11:36 AM
NeedAbout3Fiddy's Avatar
NeedAbout3Fiddy
5th Gear
Default Help with line out converter
Im trying to install a audiocontrol l2ic pro in to my 2013 gs350 with the base sound system. I've installed all my own stereos before but never dealt with a line out converter so im not sure where the best spots to hook up to the car are. Where should I be getting the constant 12v and remote 12v for the l2ic at? It's it okay to ground the l2ic with the amp im adding or should it be grounded somewhere else to avoid noise? And what speaker wires do I want to be getting signal for? Do I go for the factory sub or something with more full range signal? And help would be greatly appreciated.
Old Oct 7, 2025 | 08:21 PM
Mc44's Avatar
Mc44
Tap front speaker wires for a full-range signal. The factory sub wires are processed and will sound bad.
For power, constant 12V from the radio fuse, remote from the amp turn-on wire. Ground the L2ic and your new amp to the same bare metal spot to prevent noise.
Old Oct 8, 2025 | 01:30 AM
NeedAbout3Fiddy
5th Gear
Thanks! Do you know if any sites with good wiring diagrams? Id like to connect as much as possible in the trunk to the factory amp but cant seem to find any good wiring diagrams for it.
Sirmamaks
Jun 4, 2016 06:15 PM
MistaWong
Apr 15, 2016 11:18 AM
johnnunez2
Jun 25, 2012 06:16 PM
VTLexus
Oct 19, 2008 02:01 PM
happy_es3
Mar 1, 2008 09:54 AM
