Finally A Low Dust, High Perf Pad For The LC500
These are designed to be a perfect fit to replace the factory pads. We have now used them for a few hundred miles and are thrilled. The new pads provide great stopping power, very little dust and NO noise.
Changing pads was easy. Two bolts to release the caliper from the front hub assembly, and we used some wooden blocks to support the caliper so it would not hang free and put a strain on the brake line. The pads are removed from the “inside” and just lift out. The RB pads are designed to not use the two “shims” found on the factory pads. This gives a better pedal feel. We coated the backplates of the new pads with a light skim of brake grease to insure quiet operation, and they easily slipped into place. The RB pads actually have greater contact area with the rotor than the factory pads and this should help in high performance driving. Carefully slide the caliper back over the rotor. Depending upon how many miles are on the old pads, you may need to carefully push the pistons back into the caliper to make room for the new pads to slip over the rotor. This can be kind of “fussy” but it is not difficult. Install the new pads in the caliper and carefully pry them apart to push the pistons back into the caliper.
On the passenger side, carefully remove the Pad Wear Sensor before you remove the caliper. The RB pads have the attachment point machined into the backplates. After the new pads are installed and the caliper is on the car, you can carefully clip the Sensor back to the new pad.
RB has a specific “break-in” procedure for the pads. FOLLOW IT. Then you will finally have great, low dust brakes for the LC500.
Hopefully, as more pads are sold to LC500 owners, RB performance will be willing to fund the process of producing the rear pads for the car. This would be the final item needed to address, what is in my opinion, the greatest weakness of these cars.
Just to be clear, I have no relationship with RB Performance Brake other than being a customer. When I approached them about front pads for the LC500, they were in the process of developing the pads, but did not have a “real” customer to use to try out the pads. Warren was great to work with; they are responsive and real “stand up” people. They are a fine company to do business with.
https://www.topendmotorsports.com/le...ng/brake-pads/
Lou
