Wing Activation
Old Sep 26, 2017 | 05:36 AM
uchujin's Avatar
uchujin
Default Wing Activation
Anyone find a way to keep the automated wing logic from overriding the manual activation? It would be nice to have it remain deployed when the manual setting has been selected, but the automatic retract logic always takes over when slowing past the pre-programmed speeds while driving. According to the manual, there doesn't appear to be a dealer-programmable option for this.
Old Oct 31, 2017 | 02:15 PM
runner44's Avatar
runner44
Default Set wing constantly up
Here is how to get wing to stay up all the time. Park car, push console wing button to raise wing. Then go to settings on dash next to speedometer-set wing to OFF. Your wing will stay raised at all times.
Old Oct 31, 2017 | 04:55 PM
uchujin's Avatar
uchujin
Thanks runner44! I remember reading that in the manual (pg 395), but for some reason I confused the ABC columns and I tried to find that functionality via the Remote Touch system rather than the Meter Control Settings. When I couldn't find it in the Remote Touch Setup, I moved on to other things. This is helpful! Thanks again!
Old Nov 1, 2017 | 06:49 AM
runner44's Avatar
runner44
Default Page 395 does not help
It took me many tries to figure it out. Lexus dealers no help. Had same problem with my RCF wing.
Old Nov 1, 2017 | 01:11 PM
uchujin's Avatar
uchujin
So this process worked perfectly for me. The manual seems unnecessarily confusing. After reading that section a few times, it started to sink in... I was thinking (incorrectly) there's an automatic mode and a manual mode - where the manual mode would obey the push-button switch setting. This would simplify things greatly. In manual mode - the the wing would obey the button setting, in automatic mode - the wing would follow the drive-mode deployment settings. But it doesn't work that way and the manual seems to (intentionally???) avoid describing this option. Logically, the manual is not incorrect, it just doesn't spell out this option clearly. Probably because - there's a greater risk of the wing getting damaged if left up all the time.
Now that I know how to do this, I'm debating whether I should have ordered the pre-painted TRD lip spoiler that I'm waiting to be delivered! I may still prefer the look of the TRD version over leaving the wing up all the time. When it arrives, I'll rest it in place and see what I think. If I don't like it, it will go onto eBay - for someone with a white LC (without a popup wing) to consider...
Old May 15, 2018 | 05:40 AM
Jules640's Avatar
Jules640
Did you decide to fit the spoiler to your car? I'm sure I read somewhere that you were waiting for the warmer weather.
Old May 15, 2018 | 05:51 AM
uchujin's Avatar
uchujin
I didn't think anyone would actually remember that! Yes - I did just install it a couple of weeks ago. It's very subtle, but I like the look of the car better with it on there.
Old May 15, 2018 | 05:56 AM
uchujin's Avatar
uchujin
Old May 15, 2018 | 06:27 AM
Jules640's Avatar
Jules640
Thanks for replying and for the photos. It looks really nice and definitely improves the rear of the car. I have always thought that the rear needs something to lift it as it looks a bit 'flat'. It is quite subtle but makes a huge difference.Did you have to drill the bootlid (trunk) to fit it?
Also, do you mine me asking how much it was? It is £1,000 ($1,350) to order in the UK which seems very expensive. I'm wondering if it might be cheaper to order from the US and pay the shipping.
Old May 15, 2018 | 06:59 AM
uchujin's Avatar
uchujin
Hi Jules - If you look through this thread (link below), you'll see that I removed the pre-attached bolt. No way I was drilling the trunk. I paid way too much (~$1800 US with shipping). I seem to recall seeing much lower prices online after I bought it - but they were mostly Japanese sites. The site I used was also a Japanese merchant, but it has English text and accepts PayPal. They also responded to questions in pretty-good English. The instructions were all in Japanese, but I can translate what I did - if you end up getting one, They have a few pre-painted options as well as unpainted. You'll find a link to that site at the thread-link below.
BTW - I won't be installing the ground-effects kits. Personally, I prefer the clean lines of the lower body over the side skirts and front splitters I've seen. I just find the artistry of the clean body design more appealing. But I agree with you on the visual appeal of the trunk. I always felt it needed something, and I didn't like leaving the pop-up wing deployed all the time.
Read through this thread:
https://www.clublexus.com/forums/lc-...-lc-trd-2.html
I
Old May 15, 2018 | 09:35 AM
Jules640's Avatar
Jules640
Thanks for the information. My car is white and so I would get a pre-painted one.
I agree with your comments on the other parts of the kit, the car looks better as standard.
It seems as though quite a few owners like to change the wheels too. Personally I think the standard 21" wheels look a lot better.
Old May 15, 2018 | 11:28 AM
uchujin's Avatar
uchujin
I really like the color combination of the 21" OEM wheels too, but not the offset. I'd prefer a wider track - flush with the fenders. And the openings are a bit small for cleaning inside the barrels (which I do with latex gloves - to clean out all the nasty brake dust after every drive!). I'm likely gonna pull the trigger on a set of gloss clear polished Vossen wheels (with tires and new TPMS), and just keep my current setup for backup and/or resale.
Mohammed T
LX - 3rd Gen (2008-2021)
Jan 12, 2012 10:52 AM
Squirrelsb
HS 250h Model (2010-2012)
Mar 13, 2010 02:37 PM
brett1960
Feb 18, 2009 09:39 PM
mmmadog
RX - 1st Gen (1999-2003)
Jan 9, 2006 10:01 PM
