30k service maintenance
Old Apr 25, 2022 | 11:27 AM
LIMS407's Avatar
LIMS407
Default 30k service maintenance
Has anyone completed the 30k service?
Was quoted 1k for this and wasn't sure it was worthy or not.
Old Apr 25, 2022 | 01:55 PM
MLMLC52K18's Avatar
MLMLC52K18
NONE of the 'xxK' services are worth it imo. Just free money for Toyota!
Old Apr 25, 2022 | 07:35 PM
so do you just avoid scheduled maintenance, get it done somewhere else, or DIY?
Old Apr 26, 2022 | 12:16 AM
azmojo's Avatar
azmojo
Yes you can do it yourself or do it elsewhere, but for resale it's nice to show the Carfax showing all of the dealer services. Not sure if that adds value but it should. Probably doesn't matter if you trade it in vs sell it yourself though.
Old Apr 26, 2022 | 03:12 AM
MLMLC52K18's Avatar
MLMLC52K18
Bit--- Never said that I don’t do scheduled services, Just never felt that the prices quoted were justified.
Old Apr 26, 2022 | 07:37 AM
DAVEB1980's Avatar
DAVEB1980
I had mine done at 26k miles and it was free( car is certified) except for 2 run flats. The tires cost close to $1400 dollars with an alignment.
Old Apr 26, 2022 | 11:59 AM
pedroelbee's Avatar
pedroelbee
What all is included? The cost doesn't sound too bad for a $100k+ car, to be honest. I think it's worth it for peace of mind.
Old Apr 26, 2022 | 12:05 PM
DAVEB1980's Avatar
DAVEB1980
Mine consisted of oil change ,brake flush and fluid change, cabin and engine filter.
Old Apr 26, 2022 | 12:10 PM
pedroelbee's Avatar
pedroelbee
Ah in that case $1,000 is pretty steep. Maybe try shopping around?
Old Apr 26, 2022 | 05:39 PM
lexsc4's Avatar
lexsc4
Here in the SF bay area, the price are as follow on 30/60Ku service. Dealers here thinks we grow money on trees.
Personally I would just let them do the oil change and brake fluid flush, maybe cheaper by piece meal. The other items are check this check that.
Service - 30,000 Miles
Included Services
Replace Engine Oil
Replace Engine Oil Filter
Reset Service Indicator
Road Test
Replace Air Cleaner Filter
Measure Brake Pad Thickness and Rotor Runout
Measure Thickness of Brake Rotors
Replace Battery(s) in Master Key
Replace Brake Fluid
Replace Cabin Air Filter
Inspect Body Paint and Corrosion
Inspect Brake Lines, Hoses and Connections
Inspect Drive Axle Boots
Inspect Exhaust System and Heat Shields
Inspect Fuel Tank, Cap, Line and Hoses
Inspect Rear Differential Fluid Level
Inspect Suspension Ball Joints
Inspect Steering Operation and Linkage
Inspect Wiper Blades
Inspect Tires
Inspect Engine Coolant Level
Inspect Transmission for Leaks
Inspect Rack and Pinion Assembly
Inspect Installation of Driver's Floor Mat
Inspect Front and Rear Brake Pads, Calipers and Rotors
Inspect Transmission Fluid Cooler Hoses and Connections
$750.31
Service - 60,000 Miles
Included Services
Replace Engine Oil
Road Test
Replace Brake Fluid
Replace Rear Differential Fluid
Replace Spark Plugs
Inspect Drive Belt(s)
Inspect Tires
Inspect Engine Valves (Audible)
$1104.41
Old Apr 27, 2022 | 04:04 AM
MLMLC52K18's Avatar
MLMLC52K18
There is always some room for negotiation in their quoted price, So I am never reluctant to ask for it.
Old Apr 27, 2022 | 07:51 AM
pedroelbee's Avatar
pedroelbee
And you know they'll find something during these inspections.
Old Apr 27, 2022 | 10:30 AM
Shermang's Avatar
Shermang
"something"
Old Apr 27, 2022 | 02:14 PM
lexsc4's Avatar
lexsc4
Originally Posted by Shermang
"something"
The service advisor suggested Rust Proof coating and I am in the bay area. Should I get it done?
Old Apr 27, 2022 | 08:57 PM
no... waste of money unless your car is routinely sprayed by salt water.
