Help with 2025 Bespoke decoding?
Old Jan 14, 2026 | 11:39 AM
CJS57's Avatar
CJS57
Default Help with 2025 Bespoke decoding?
It is a 2025 LC 500 coupe in transit. Can't seem to figure out how to find out what options are included in the $3600 Bespoke package? It also has a carbon fiber package that is a seperate line item on the window sticker and has its own cost on that line item.
Old Jan 14, 2026 | 01:44 PM
np20412's Avatar
np20412
There was no such thing as "Carbon fiber package" so I'm curious what that line item is. The only options for carbon fiber on the bespoke coupes in 2025 were the carbon fiber roof and the carbon fiber door sills, both listed as their own line item options at ~$2000 and ~$600, respectively.
The bespoke package includes:
- Yamaha rear performance dampers
- Torsen Limited slip differential
- high performance brake pads
- cold weather package
Old Jan 14, 2026 | 03:00 PM
CJS57's Avatar
CJS57
I mis-spoke on the terminology. The window sticker says carbon fiber roof - $2400 and carbon fiber scuff plates - $600. So are those costs included in the $3600 Bespoke charge or additional on top of the $3600?
Old Jan 14, 2026 | 04:20 PM
np20412's Avatar
np20412
Those are on top of the bespoke package. Sorry $2400 sounds more likely for the CF roof, I misremembered in my original post with the cost of HUD and ML being around $900.
Old Jan 15, 2026 | 02:57 PM
NorvilleRogers's Avatar
NorvilleRogers
10th Gear
When I ordered my Bespoke ‘25, the cold weather package (heated steering wheel & windshield wiper de-icer) was a $250 option. It was not included as part of the Bespoke package.
Old Jan 15, 2026 | 03:18 PM
tecman's Avatar
tecman
I have the Cold Weather Package, the heated steering wheel works well, but I don’t know anything about the wiper deicer. Has anyone used it? Is it automatic or is there a button for it?
Old Jan 16, 2026 | 07:55 AM
2959's Avatar
2959
I believe it's selected in the Climate-options section and appears to "heat" the windshield at the bottom and sides. Mine has it but I've never operated the vehicle below 40* so I'm not sure if it does as engineered (doesn't say what the "on" temperature is or where the temperature is coming from).
Old Jan 16, 2026 | 12:20 PM
Hythe's Avatar
Hythe
Not sure if this is the case on the 2024+ cars, and there is nothing even about it in the manual... I shall have to have a play around with mine this evening...!
Old Jan 16, 2026 | 12:52 PM
2959's Avatar
2959
Just checked the ‘24 pdf, look on page 83 in the Climate section.
File Type: pdf
File Type: pdf
Old Jan 17, 2026 | 11:43 AM
ratchettt's Avatar
ratchettt
It's on page 296 of the 2025 pdf. But after reading it's unclear how it operates. There is a manual engagement option as in your link on the concierge to deice, but surely there is automatic activation (?).
Old Jan 18, 2026 | 08:03 AM
2959's Avatar
2959
Maybe it functions with the windshield defrost selection? Mines under wraps for the winter so I can’t verify.
Old Jan 18, 2026 | 10:40 AM
tecman's Avatar
tecman
18-23 LC500 deicer
2024 LC500 deicer
Old Jan 18, 2026 | 11:32 AM
ratchettt's Avatar
ratchettt
Default 18-23 LC500 deicer, tecman
Goodness sake interesting. True or False
-Some or all commands are sent wireless.
-There is no deice on the wiper per se except heat transferred from the windshield deice.
Old Jan 18, 2026 | 12:42 PM
NickL's Avatar
NickL
De-icer is easily seen on the bottom of the windshield. It’s the heating lines directly under the wipers.
The function to turn it on and off is in the climate under more option.
It’s the cold weather package for $250. This is a no brainer to me.
Old Jan 18, 2026 | 01:01 PM
ratchettt's Avatar
ratchettt
Thanks. As far as you know that portion of the windshield deice/defog under the wipers only activates with the manual selection in concierge?
