Weird (Minor) Issues - New Battery Needed?
Old Oct 16, 2025 | 12:33 PM
Cja7720's Avatar
Cja7720
10th Gear
Default Weird (Minor) Issues - New Battery Needed?
Just picked up car few days ago. Having a few weird minor issues with the car, feel like they can be attributed to potentially needing to replace battery. I didn’t see it on the CARFAX as being done recently but highly doubt it’s original since car is 2018.
-car cranks fine but takes a bit to turn over on some starts
-up shift paddle wouldn’t work for a bit once but came back. Wouldn’t rev match downshifts either.
-seat memory doesn’t work when I first get in but will start working when I open door, turn on engine, etc. very inconsistent
-at low rpm’s the car seems to disengage the gear? Appears that this is normal and contributes to the clunkiness of the ‘18 transmission.
Not all battery related but wondering if one or more of these are indications I need a new battery. TIA!
Old Oct 16, 2025 | 12:38 PM
355F1's Avatar
355F1
Probably battery.....you can go get a load test for free and soooo many places to determine, you know.
Old Oct 16, 2025 | 12:44 PM
Cja7720's Avatar
Cja7720
10th Gear
thank you, ill probably just go buy a replacement.
Old Oct 16, 2025 | 01:55 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^If you do, you'll want to read this thread:
https://www.clublexus.com/forums/lc-...1-battery.html
In its entirety
Lou
Old Oct 16, 2025 | 04:40 PM
Cja7720's Avatar
Cja7720
10th Gear
I just got it tested and guy said it was fine. Guess I shouldn’t touch it.
Old Oct 16, 2025 | 04:41 PM
Cja7720's Avatar
Cja7720
10th Gear
In its entirety
Lou
thank you. Ended up testing fine. So guess it’s all good.
Exulter
Jan 1, 2024 11:07 AM
HerbTarlek
Dec 25, 2019 08:40 PM
jimisbell
Aug 10, 2017 06:27 PM
jjscsix
Mar 10, 2015 07:04 AM
chnk
Dec 23, 2010 03:07 AM
