What temperature for Transmission Fluid Check?
Old Oct 13, 2025 | 11:46 PM
Dsmdriver2588's Avatar
Dsmdriver2588
4th Gear
Default What temperature for Transmission Fluid Check?
Hi everyone. Does anybody know what the correct temperature is i should check for the level after changing out the transmission fluid?
Old Oct 14, 2025 | 10:48 PM
Dsmdriver2588
4th Gear
Nobody knows?
Old Oct 14, 2025 | 11:53 PM
104°F to 113°F on other Toyota transmissions I've worked on that take WS fluid so yours is likely the same.
Old Oct 14, 2025 | 11:55 PM
Dsmdriver2588
4th Gear
Thanks
Old Oct 16, 2025 | 03:45 PM
hainess's Avatar
hainess
What are you going to use to measure the temperature? I'm going to do it when I reach around 60k and bought OBD fusion but just curious as to what other are using.
Old Oct 16, 2025 | 03:48 PM
Dsmdriver2588
4th Gear
Believe it or not, I use the Hyper Tough HT 500 Bluetooth scan tool from Walmart.
Old Oct 16, 2025 | 03:57 PM
Oro's Avatar
Oro
The fluid volume difference in the pan of a typical 9qt transmission, based on temp, is about 3 ounces between 70f and 120f. As long as it’s between “room temp” to “not scalding” - the actual temperature is irrelevant. ATF volume changes very, very little by temp. If you don’t have a tool to check temp, don’t waste $$ on one. And if you have one, it’s really not important to waste time on it (I do not).
B777Pilot
Feb 24, 2022 09:47 PM
manifesto
May 5, 2018 10:23 AM
mylexus350
Dec 5, 2011 09:26 AM
ron36330
May 26, 2003 01:17 PM
