Modified/New Door Latch
Old Aug 8, 2025 | 09:45 AM
BriTex's Avatar
BriTex
Default Modified/New Door Latch
Hi All,
Recently saw a video on the Pinnacle edition, the guy went on about the "New" door latch.
Rubber covered (or not) and 1mm or something thicker (Increasing the handling/comfort... skeptical).
I've seen this Mod mentioned in other forums/comments but no real details of what it is trying to improve or how?
Any idea's guys/gals?
Old Aug 8, 2025 | 11:08 AM
tecman's Avatar
tecman
TRD has been making door stabilizers for over 10 years. I don’t know why they aren’t more common, and in the Lexus lineup they only fit the IS.
Old Aug 8, 2025 | 11:16 AM
tecman's Avatar
tecman
The two links I tried to post above were fighting each other, here's a link to the product.
https://www.trdparts.jp/english/prod...unctional.html
Edit: they do have them for other Lexus models.
https://lexusboutique.net/search?q=Door+stabilizer
Old Aug 8, 2025 | 11:25 AM
np20412's Avatar
np20412
This is the excerpt from Lexus Boutique: New feature – an industry first (patent pending)
Fills the gap in the door striker area using a spacer. This provides quicker steering response by cutting down the delay from when the steering wheel is turned. The built-in sliding mechanism automatically adjusts the gap to zero. Designed to be easy to install yet maintains a strong visual presence.
Can anyone help me understand the connection here? Does it have to do with chassis flex?
Old Aug 8, 2025 | 01:21 PM
400Mman's Avatar
400Mman
Ha!
I share the same curiosity. I’ve seen a few comments about 2026 LC 500 new door latch/ hinge increases the car’s chassis stiffness and rigidity. I’ve yet to come across an actual explanation of how.
The 2025 coupe received added underfloor front and rear braces. This is straightforward and understood. Door hinges making a difference?
Old Aug 8, 2025 | 02:11 PM
ratchettt's Avatar
ratchettt
As a total ignoramus, but also curious one, I can only say this maybe THE top tier example of the meticulous engineering detail we all enjoy right down to a latch for heavens sake (improving weight and handling even if infinitesimally). Feeling this has to do with reducing the longitudinal flex of the inside and/or outside body in cornering. Still curious. Speaking Japanese might help, but in my case unlikely it would.
Old Aug 8, 2025 | 02:24 PM
glennbaz's Avatar
glennbaz
Sorry, I'll do a hard pass on this one. Anyone who actually does buy and install this piece please report back. I find it difficult to believe that it would make even the tiniest improvement in handling. This is like pushing of beefier engine bay cross support to improve handling. Just how hard is anyone pushing these cars to make any noticeable difference. Much like people throwing the words "turbo lag" around like they are all lndy drivers.
Old Aug 8, 2025 | 02:34 PM
ratchettt's Avatar
ratchettt
Not sure the aftermarket kits are the issue. Just that the 2026 LC's apparently have some adjustment to the door latch mechanics and why.
Old Aug 8, 2025 | 02:43 PM
400Mman's Avatar
400Mman
All reasonable points you state and thus the curiosity. If the Lexus engineers did make this change to the 2026 LC 500 one would assume that they had concrete reasons for doing so. How much of a real world difference does it make? I’m just intrigued to know the engineering explanation. Over the years it seems that the subtle refinements done to the LC 500 are worthwhile.
Old Aug 8, 2025 | 05:21 PM
NickL's Avatar
NickL
I think the engineers had a few too many sake.
Old Aug 8, 2025 | 06:26 PM
StuM's Avatar
StuM
Default Sake Abuse!
Agree. This, or the Lexus Marketing team needed more filler for the newest model.
Old Aug 8, 2025 | 06:58 PM
400Mman's Avatar
400Mman
Perhaps. If on the other hand you review the track record of LC 500 updates and refinements since 2nd model year (2019) you’d be hard pressed to say that any were trivial. Based on past efforts I’ll give them the benefit of doubt.
Old Aug 8, 2025 | 10:20 PM
400Mman's Avatar
400Mman
Japanese video but can use auto translation to English.
Apparently the car door is viewed as the weakest link in establishing chassis rigidity. These modified door latches help to secure a tighter or firmer connection between the door and the car frame. This is said to reduce the “flex” in the doors thus improved stiffness. I imagine the change is modest (But every little bit helps).
The LC 500 has pretty substantial size doors that could contribute some detrimental flexing ?
Anyway Lexus engineers felt improved latches (More stable door to car frame grip) were a justifiable addition for the 2026 models.
Old Aug 9, 2025 | 05:16 AM
barncobob63's Avatar
barncobob63
door latches..its an open/shut case in my engineering experience.
Old Aug 9, 2025 | 05:35 AM
400Mman's Avatar
400Mman
Japanese test drive. At 13.21 the discussion concerning the new door striker/ latch begins. They compare a Lc 500 with old va new door striker.
