I have a 2021 LC 500 convertible, liquid platinum. It does a great job hiding small rock chips but I'd like to get some touch up paint. Who do you guys recommend? Thanks.
Agree with touchupdirect, did all of the cars damage repair on the 2016 ES and the paint matched perfectly using their filler, primer, color and clearcoat . Although my paint/body work skills are by no means great.
Body shop wanted close to 20K for the work on a car that's not even worth that (mostly side-swipe repairs, no frame damage).
I purchased factory touch up in Infrared color. Problem is, it is too dark and does not fully match for some reason. I'm looking for some way to try and thin it out to lighten it up.
I used this matched perfect. Purchased at Walmart.
sometimes the best approach to fixing minor paint damage is, after
cleaning the repair area, obtain a drop of paint on the end of a needle,
and allow the drop to fill the void by capillary action; no brushing needed.
after a few days you can buff the repaired area, or just leave it be.
Thanks for your suggestion. I am well experienced in many ways to apply the paint. My issue was the color match. Also there is a product called Langka that works well for smoothing the touch up area after painting.
