LC500 2024 Valves
Old Dec 8, 2024 | 02:13 PM
RaZkMan's Avatar
RaZkMan
Default LC500 2024 Valves
Hello, I own a 2024 LC500 and I want to open the valves. I saw a device for this on the internet that was controlled with a wireless remote control. When I talked to the seller, he said that it is not compatible with vehicles with 2024 new generation multimedia systems, so it is not compatible with my vehicle. Can anyone with experience tell me how I should proceed? I saw a video saying that if I remove a few cables that control the valves at the exhaust outlets, the valves will always remain open. Is this video valid for 2024 models?
Old Dec 8, 2024 | 02:45 PM
flowrider's Avatar
flowrider
Veteran: Air Force
You may want to explore this thread:
https://www.clublexus.com/forums/lc-...valves-12.html
Lou
Old Dec 8, 2024 | 02:48 PM
np20412's Avatar
np20412
Yes you'll have to manually unplug them and then you're good to go.
Old Dec 8, 2024 | 03:17 PM
Young04's Avatar
Young04
Yes, you can manually unplug the valves. If you have a convertible, it's two valves, not four like the coupe. It's still fairly quiet with valves open all the time. That's how I ran my 2024 LC until I put on an aftermarket exhaust a couple of months ago.
Old Dec 9, 2024 | 12:38 AM
RaZkMan's Avatar
RaZkMan
So, is there really much difference in the sound when the valves are open?
Old Dec 9, 2024 | 09:54 AM
Young04's Avatar
Young04
At low RPMs yes. I would say it is worth doing.
Old Dec 10, 2024 | 12:15 PM
RaZkMan's Avatar
RaZkMan
Hello, I removed the valve cables and the sound was really good. I covered the ends of the cables with three layers of electrical tape. Do I need to do anything extra? It rains a lot in the city I live in. God forbid, what happens if the water passes through the band and touches the cable? What extra precautions should I take to prevent this from happening? Thanks
Old Dec 11, 2024 | 07:37 AM
ragabnh's Avatar
ragabnh
Out of topic, I spent summers in Istanbul to escape Las Vegas heat. I own LC in the US and I was looking to buy a car there. This thing cost close to $300k where you live, quite expensive indeed.
Old Dec 11, 2024 | 10:36 AM
RaZkMan's Avatar
RaZkMan
Yes, unfortunately, the tax system in my country is a complete disgrace. Currently, the sales price of the LC500 is $450,000 in dollars. I'm buying 3 for the goverment and one for myself 😂
Old Jun 18, 2025 | 06:54 AM
DDLexus's Avatar
DDLexus
I also saw someone on YT post a video about removing a fuse from the trunk fuse box that would deactivate the exhaust valves. It was stated that if you remove the fuse, you don't have to do anything with the electrical plug under the car near the valves. This would ensure no water gets into the undercar connections. Not sure what else might be controlled by the fuse, but that could be another option.
Old Jun 18, 2025 | 07:05 AM
np20412's Avatar
np20412
Not possible on 24+. Wiring was changed and fuse no longer exists for this purpose.
Old Jun 18, 2025 | 07:52 AM
dodgediesel's Avatar
dodgediesel
I really want to unplug them but without a proper protective solution I won't do it. I don't wanna ESD bag the connectors and tie them off. I heard someone mention that Toyota has connector plugs that are available but its impossible to find out the part numbers and that guy who managed to get them didn't even drop the part numbers.
kcook440
Sep 19, 2022 05:50 PM
swfla
Jun 26, 2022 01:35 PM
John Coyle
Feb 1, 2015 02:51 PM
ChuH
RC F (2015-present)
22
Aug 13, 2014 03:37 PM
