AC not working
Old Dec 2, 2024 | 02:15 PM
web4488's Avatar
web4488
Default AC not working
Thought I would inquire here before making an appointment at the dealer. My nearly 7 year old 2018 LC might have it's first problem. When the ac is on, I can't get air to blow through the main vents. The windshield vent and the lower vents are working, but the main vents are no bueno. Anyone have this happen and got it fixed? This issue just started.
Old Dec 3, 2024 | 12:57 AM
jelee's Avatar
jelee
Same thing happened to my 2018. It is a known issue. There is an LSB for it.
https://www.carcomplaints.com/Lexus/...-0009-22.shtml
https://static.nhtsa.gov/odi/tsbs/20...11788-9999.pdf
The fix for mine was the first step of reprogramming and cleaning the servos. They did not have to replace the servos. We will see over time if the fix works or not which would then require new servos.
Since you also have a 2018, also check for condensation/fogging in your rear view camera housing. I had to get my rear view camera exchanged because of fogging and condensation inside the lens.
Old Dec 3, 2024 | 01:36 PM
web4488's Avatar
web4488
Excellent! Thanks much for taking the time on this response. Very helpful!!
Old Dec 3, 2024 | 02:18 PM
jelee's Avatar
jelee
You are welcome!
Old Dec 5, 2024 | 12:05 PM
alsilverbullet's Avatar
alsilverbullet
I had the same issue on my 2018 and the dealer reset the servos by installing a software update. Took 40 minutes and I was on my way. Best news as I was anticipating spending $$$$
Old Dec 6, 2024 | 06:04 AM
IcyBishop's Avatar
IcyBishop
I had the same issue when I first got mine.. a cycle of the battery fixed it.
Old Dec 6, 2024 | 01:59 PM
web4488's Avatar
web4488
So before I could make an appointment, the vents started working again! WTH!
Old Dec 6, 2024 | 02:14 PM
jgscott's Avatar
jgscott
The Dealer can Re-calibrate the Servo gears. It also runs them backwards some to try and Re-lube them in reverse.
On some Lexus's it was a update. They sent a letter to owners. The letter also showed a expire date. Should all check. This Servo motor problem is across all Lexus Models.
Old Dec 6, 2024 | 09:10 PM
jelee's Avatar
jelee
It is also known to be intermittent. Mine was intermittent. It would work one day and not another and then work, So still make the appointment as they will also check the car's computer for the error codes.That is how they confirmed mine was acting up based on the error codes and thus it qualified for the Lexus Service Bulletin Fix.
Old Dec 7, 2024 | 01:16 PM
Barncobob's Avatar
Barncobob
unhooking the battery can solve a myriad of issues in all makes..
XSV
GS F (2016-present)
12
Oct 20, 2024 12:04 AM
mcgene
May 16, 2024 01:33 PM
Hermyherm
GX - 1st Gen (2003-2009)
15
Aug 28, 2023 03:34 AM
JBeau
IS F (2008-2014)
Jul 2, 2023 02:39 PM
Narift
Apr 12, 2023 05:48 AM
