Issue with rear wing?
Old May 13, 2024 | 06:50 PM
FranknStein's Avatar
FranknStein
Default Issue with rear wing?
I have a ‘24 bespoke coupe and have noticed one odd thing with the speed activated rear wing. If I press the button on the center console to manually keep it raised, I can’t seem to lower it back down again. Basically if I press the button again, the spoiler goes down but then immediately goes back up. The only solution I’ve found is to press it so it goes down and immediately turn the car off. I assume this is not the normal behavior.
Old May 13, 2024 | 08:21 PM
flowrider's Avatar
flowrider
Veteran: Air Force
From Owner's Manual:
Lou
Old May 14, 2024 | 04:48 AM
FranknStein
Lou
Thanks. I tried holding the button down, but maybe I didn’t do it for long enough. Will give it another try. I’m confused what “the active rear wing retracts when it is raised and raises when retracted” means.
Edit: Nevermind, I think I understand. The way this whole section is written is a bit confusing.
Old May 28, 2024 | 08:31 AM
FranknStein
Yes, it turns out I was just not holding the button down long enough. To bring the wing back down you have to hold it for a few seconds.
Enzo954
Oct 22, 2023 01:38 PM
krafty81
RX - 5th Gen (2023-present)
Jul 30, 2023 12:01 PM
Jsal
NX - 1st Gen (2015-2021)
Jan 3, 2022 09:42 AM
GOT8SPD
RC F (2015-present)
Feb 26, 2020 11:07 AM
lex460l
Nov 24, 2016 12:29 PM
