Wireless Carplay adapter not working after service?
Hi all, I took my '21 in for a 10k service last week, and now my wireless carplay module doesn't work. I'm guessing they must've done some sort of software update, but it was working perfectly up until then. Anything I can check? It's a "auerds" brand from Amazon. I've tried their service but they're telling me the car's not compatible. Which...it was up until last week!
Thanks.
Thanks.
Thanks! I did try unplugging and re plugging, that didn't work. There are two ports - upper and lower. I'll try it in both. It's not the cable, because it's an adapter. I can see the bootup screen of the module, but then nothing happens. I just found it a really odd coincidence that it stopped working right after a service, figured it may have been a software update.
great choice (that's my other car too, hahaha).
ok, so def. a car problem. i doubt it was a software update though... maybe they forgot to put a fuse back in. can you plug anything else in the usb port to see if it's working? (flash drive with music files, or even... does the phone charge when plugged in directly?).
Carlinklife Apple CarPlay/AndroidAuto integration kit for 2014-2019
Our Apple CarPlay/AndroidAuto integration kit will give you the ability to add-on functions for Apple CarPlay and Android Auto to your Lexus’s existing entertainment system.
To control and switch the apps within Carplay, it is integrated with your vehicle’s **** controls and original touchscreen.
Or you can control it with your voice thanks to Siri/Google Assistant.
You will not lose any functions from your original system, the integration kit will work as an added function.
The kits will come with the required module and all the necessary wires to complete installation in your vehicle.
Version 2 Improvements:
– No need for a separate Microphone for Siri/Google Assistant as the kit uses Original microphone
– Wireless AndroidAuto is now supportedFeatures of our kit:
– Wired/Wireless Apple CarPlay
– Wired/Wireless Android Auto
– Easy control with vehicles built-in controls
– If your vehicle has original Rear View/Surround View cameras, those will continue working the same way
– This module can be extended with Front/Rear view camera (if your vehicle didn’t come with those originally from the factory)
– Supports touch screen.
LINK:Carlinklife Wireless CarPlay Android Auto Module For 2014-2019 Lexus
Enjoy $30 OFF + Worldwide Free shipping ! (USE CODE: CLUBLEXUS )
Only for clublexus forum members!
Well, I finally realized I have another of the same modules in my other car. Swapped them and lo and behold, one works and one doesn't. So it's the stupid module. I never should've doubted my trusty Lexus
