Replace passenger side direct injector?
Old May 3, 2021 | 07:57 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Originally Posted by 6t8AMXETC
Those who have done this. What are you using/doing for the supposed critical torque angle settings (with SST's) on the high pressure line or fuel pressure sensor?
The SST for the fuel pressure sensor is not needed. There is no reason at all to remove the HP fuel pressure sensor, and the FSM actually does not have any procedure for doing this outside of Safety Recall ELF, and the tools used for that recall are not generally available to the public. Lexus will not sell you a pressure sensor, they will only sell the rail with the sensor already installed.
Originally Posted by FSM
NOTICE:
  • Do not remove the fuel pressure sensor from the fuel delivery pipe assembly LH.
  • If a fuel pressure sensor is removed, replace the fuel delivery pipe assembly LH (fuel pressure sensor) with a new one.
There is no magic tool for connecting the high pressure fuel lines. All you need is a standard flare crowfoot and a standard torque wrench. That's how I did mine when I did the valley plate repair on my car last October. Piece of cake.
Old May 3, 2021 | 04:42 PM
6t8AMXETC's Avatar
6t8AMXETC
Unhappy
Welllll, that is what I was referring to. Sorry should have been clearer. When I pulled mine apart to do the valley plate sealant, I decided to pull the Fuel Pressure sensor for access to the plate. BEFORE reading up on the ELF recall and it's specific tools and torque angle gauge for tightening the sensor! Just wondered if anyone else has dealt with theirs? Thanks for the insight.
Old Feb 18, 2023 | 05:14 PM
mikoriad's Avatar
mikoriad
Default Direct injector replacement
Originally Posted by fstpassat
So I am in the middle of the valley plate fix and I am pretty sure I broke the connector on the passenger side rear direct injector. It is very flimsy compared to all the other injectors which have almost no play in them. See the following video.
https://youtu.be/Z-keUygtoXQ
Any ideas what I need to replace other than the obvious injector? Seals as well? Any concerns or cautions before pulling that fuel rail? I have never messed with direct injection before. I will google the part number for that injector and any advice is appreciated.
How did you fair, were you able to replace yours? Any pointers from you experience would be awesome. I am currently in the exact situation. I removed/resealed the valley plate and also the valve covers. I did the same thing and broke a couple of passenger side direct injectors which now must be replaced. I ordered them but would love some first-hand knowledge before I start.
Old Jan 15, 2024 | 08:00 AM
Mehdiakss's Avatar
Mehdiakss
1st Gear
Default I have same problem
That blows. Injector and seals for sure, maybe a new connector body on the harness as well. The factory has some very specific instructions on how to replace the injectors. PM me for more info.
hi dear
would you please to send me information how to replace this high pressure injectors i have miss fire cylinder 3 and now i understand the gasket of this injector have leaked and need to change i need to know how to replace it , the access to this injectors is really difficult
Old Jan 15, 2024 | 08:49 AM
mikoriad's Avatar
mikoriad
Originally Posted by Mehdiakss
hi dear
It is definitely time consuming and daunting. You will basically be doing the same procedure as the valley plate repair. Parts will be everywhere and you have to be organized. The intake has to be removed, which involves getting a lot of parts out of the way. Once the intake is off, you can get to the injector rail. The difficult part is getting to the high pressure fuel rail.
fblonk
Sep 15, 2025 05:52 AM
2jznat
Jun 3, 2005 09:37 AM
