Single Turbo ISF Build
Old May 19, 2020 | 03:16 PM
Defratos's Avatar
Defratos
Question Single Turbo ISF Build
Anyone come across this build?
View this post on Instagram
Hope it's ok sharing Instagram links
Old May 19, 2020 | 04:56 PM
Wh0pp3r's Avatar
Wh0pp3r
I...I.. don't know about this...
Old May 19, 2020 | 05:08 PM
MileHIFcar's Avatar
MileHIFcar
Yea I saw that too.....interesting to say the least
Old May 19, 2020 | 05:27 PM
Jwconeil's Avatar
Jwconeil
I’d love to know what power it made.
Old May 19, 2020 | 06:20 PM
Vervish's Avatar
Vervish
I wonder how the cold piping Is making it back into the engine?!
Also, says “Sin Tuneo” - that’s without a tune?!
Old May 19, 2020 | 06:24 PM
Vervish's Avatar
Vervish
Also wondering if they are using one side (4 cyls) of the exhaust to spool the turbo?
Old May 19, 2020 | 07:34 PM
WillAP1's Avatar
WillAP1
I know the video peaks a lot but does anyone else feel like there wasn't very much turbo sound? Especially at the end of the run. I'm not saying it's fake (not hooked up), but at the same time I really wouldn't be surprised... I searched their page and couldn't find any pics of what the hotside either...
Either way, definitely interested to see more.
Old May 20, 2020 | 09:39 AM
MisterSkiz's Avatar
MisterSkiz
Sin Tuneo lol - probably running small boost
Old May 20, 2020 | 07:19 PM
Joe Z's Avatar
Joe Z
FWIW I grabbed this photo off the IG story board...
Doesn't mean much unless you know all the before & after or even the dyno variables used..
Old May 21, 2020 | 05:58 AM
Defratos's Avatar
Defratos
Ok great so I'm not the only one surprised and lost here , will keep following his progress to see if there's any interesting results.
Old May 22, 2020 | 02:06 AM
IronNam's Avatar
IronNam
Why would they do that?...
Old May 22, 2020 | 05:38 AM
Vervish's Avatar
Vervish
no clue - just not understanding how they could have piped the passenger side exhaust manifold to the driver side mounted turbo and still maintain enough ground clearance. Maybe there is more space than i think...
Found a photo of the cold piping route tho.
Old May 22, 2020 | 08:18 AM
jdmek998's Avatar
jdmek998
It will be interesting to see the full setup.
Old May 22, 2020 | 06:29 PM
ultimase's Avatar
ultimase
Not that uncommon with V configured motors. In order to get both exhaust banks to contribute you'd need to wrap the exhaust manifold around the motor, or consider mounting the turbo as a rear mounted setup. The position of the turbo immediately next to the intercooler does make me think it's only being fed off one bank. With proper turbo sizing you shouldn't really need both banks contribution. The only issue then would be that there would be significantly more back pressure on one side of the motor versus the other.
Old May 23, 2020 | 12:44 PM
Jwconeil's Avatar
Jwconeil
I’ve put some thought into putting a turbo where the oem air box is, running headers the opposite direction and piping them all together. My conclusions are, it won’t fit without hacking the car and hood up, if even then. That’s a pretty big wheel, it’d be a shame if it was only running on one bank, and it’s overkill. If it’s running on all cylinders, then it’s more appropriately sized.
