Noises after coilover install
Old Mar 31, 2020 | 01:51 PM
AKA1396's Avatar
AKA1396
Default Noises after coilover install
I recently installed coilovers on my Isf in the front and I’m hearing noises like maybe metal against metal or something of that nature I rechecked my work we tightened and torqued everything to spec but I still hear that noise it’s like a knocking noise sometimes when I’m going over certain road conditions basically at an a slower speed than usual
Old Mar 31, 2020 | 02:25 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Did you tighten everything with the suspension loaded at normal ride height?
https://www.clublexus.com/forums/sus...ere-first.html
Old Mar 31, 2020 | 04:54 PM
lexicon72's Avatar
lexicon72
What coilovers? Do they have metal top hats?
Old Apr 1, 2020 | 05:11 AM
jdmek998's Avatar
jdmek998
Make sure everything is tight. Recheck. Sounds light something might not be tight causing the the noise.
Old Apr 1, 2020 | 06:23 AM
Ah Lau's Avatar
Ah Lau
I had this problem.
What is happening is that everything is tight as can be, then when the spring is SLIGHTLY compressed (eg going over a small bump), tension builds up because the spring cannot slide across the top or bottom surfaces of the shock, and then when it SUDDENLY moves, it makes a pop or twang sound.
I solved it by installing thrust needle bearings.
More information:
https://www.clublexus.com/forums/is-...ml#post9694768
ndk350
RC - 1st Gen (2015-present)
Mar 27, 2020 05:56 AM
Jordan345
IS F (2008-2014)
24
Jul 10, 2019 06:10 PM
D&G
Jan 28, 2014 10:31 PM
ROK
IS F (2008-2014)
Sep 22, 2013 08:42 PM
nsxiboi
Suspension and Brakes
Nov 19, 2012 12:45 PM
