BC Coilover Spring Rates
Old Nov 1, 2019 | 08:32 AM
nickj718's Avatar
nickj718
Default BC Coilover Spring Rates
Searched but couldn't really find any solid info
I have some BC Coilovers that I have sitting around and im curious as to what spring rates you guys are running for your street/ track cars
Currently they are the R-02-BR and rates are 12k up front and 10k out back
Old Nov 1, 2019 | 10:53 AM
Vervish's Avatar
Vervish
I run 16K/12K swift springs - ride pretty good on street (I have not tracked them).
Old Nov 1, 2019 | 05:09 PM
GS3ooMania's Avatar
GS3ooMania
I have the same and rides way better than 08 stock. Feels more planted and would recommend RRRacing USRS if you plan on running 20s. Helped alot with bottoming out. PM if you have any other questions. Its boost season so hows it going?
Old Nov 2, 2019 | 12:24 AM
OneFastF's Avatar
OneFastF
18k/14k here. BC R DS series. Felt nice on track and canyons. Maybe a bit stiff for some on the streets. I think 18k/12k would be a perfect combo.
Old Nov 6, 2019 | 07:42 PM
ISFpowered's Avatar
ISFpowered
Had BC coilovers 16F/14R and felt they were to soft especially for the weight of the car. Now I have Penske 18F/16R and they are perfect!
Old Nov 7, 2019 | 06:48 AM
Vervish's Avatar
Vervish
OP - please keep in mind that it's not as simple as adding stiffer springs. I believe the BC's come specifically valved for the spring combo they are ordered with. So stiffer spring on a shock valved for a softer spring may not work right.
Old Nov 8, 2019 | 08:42 AM
MoarLow's Avatar
MoarLow
I use whatever they came with, works fine for DD purposes!
Old Nov 8, 2019 | 09:05 AM
LexusfanVA's Avatar
LexusfanVA
I've had BC Racing with 14/10 swifts and 16/12 swifts, both were the cheaper $1200 models. Both rode much smoother than my 08 stock suspension and handled harsh bumps better, yet neither are as sporty.16/12 ride better and won't dip or rub as much if you want to lower the car more than an inch..I currently run HKS 16/10 and they ride a bit rougher than the 16/12 BC swift, but are more stable in the corners and seem better made.
However, I am currently irked by HKS because my front damping adjustment **** somehow got lost and it's not under warranty nor can anyone sell me a piece. I understand it's SEMA month, but HKS can tell me what part # I need, yet no reseller/distributor can order them in the last 3 weeks. Just a rant..
Old Nov 22, 2019 | 11:31 PM
t0e's Avatar
t0e
You Sir, are correct.
I've attempted this one time, and it didn't work, as we figured it wouldn't. Just had to experiment, oh well...
Old Nov 22, 2019 | 11:34 PM
t0e's Avatar
t0e
Where did your source the Penske's from?
Old Nov 23, 2019 | 06:32 PM
3nergiz3d's Avatar
3nergiz3d
You can grab them RR Racing or Figs Engineering.
mdgrwl
Suspension and Brakes
27
Apr 10, 2026 10:12 PM
Jz39
IS F (2008-2014)
Feb 17, 2018 01:29 PM
pwrusr
Suspension
Jan 5, 2016 08:52 PM
Studiogeek
Jan 9, 2014 12:26 PM
panda327
May 9, 2011 06:28 PM
