Wild cabin noise!
Old Sep 13, 2019 | 09:06 PM
Grosen84's Avatar
Grosen84
Default Wild cabin noise!
6 weeks in and I'm already glad I got the extended warranty. This morning I start the car and hear what I swear is an air compressor running in the cab. Does it for 30 seconds every time I start the car. Dealer thought they'd have it and a new GPS recall handled today. Called at 4 to say they'll need it til Monday. Anyone else have this experience? Airbag recall was completed recently by a different dealer according to the one I left it with.
Old Sep 14, 2019 | 04:58 AM
M4rk's Avatar
M4rk
Isn't the airbag recall now done through the glove box? If that's the case, it would confirm my initial thought that it sounds like the motor responsible for moving the recirc flap (also behind the glove box) is spinning its gears. I would guess something wasn't put together correctly.
Old Sep 14, 2019 | 08:33 AM
Wh0pp3r's Avatar
Wh0pp3r
So wouldn't that mean if you attempt to cycle that motor settings and no change would mean the gear is stripped?
Old Sep 15, 2019 | 03:58 AM
M4rk's Avatar
M4rk
Yes, stripped or maybe just misaligned although I've never had that part of car disassembled. Further, the sound/tone of the air circulating changes slightly between fresh/recirc modes. No change in tone could be further indication of damaged recirc mechanism. Gotta open it up.
Old Sep 16, 2019 | 01:09 PM
4cedfed22's Avatar
4cedfed22
Keep us posted on what it is.
Old Sep 16, 2019 | 02:03 PM
Grosen84's Avatar
Grosen84
Reportedly a screw from the airbag recall repair that fell into the blower...screw was extracted per the dealer but I haven't been in person to talk it over.
Old Sep 16, 2019 | 09:35 PM
Joe Z's Avatar
Joe Z
Lightbulb
WoW..!! A screw in the spin cycle.. In theory no noise if the entire HVAC system was off..
Make sure you get a new a/c filter put in by them too
Joe Z
Old Sep 16, 2019 | 09:49 PM
mallninja's Avatar
mallninja
Wow that sound was awful. Glad it was an easy fix and not something worse.
Old Sep 17, 2019 | 07:49 AM
Grosen84's Avatar
Grosen84
Originally Posted by Joe Z
WoW..!! A screw in the spin cycle.. In theory no noise if the entire system was off..
Make you get a new a/c filter put in by them too
Joe Z
I cut the video after it stopped, it did only run 30 sec on startup so I knew it was something computer controlled and switchable.
daryll40
Feb 11, 2017 06:13 AM
al503
May 25, 2008 06:41 PM
erinb007
RX - 1st Gen (1999-2003)
13
Apr 12, 2004 06:35 AM
