Sliding Causing Transmission Problem?
Old Jun 17, 2019 | 04:43 PM
vraa's Avatar
vraa
CL Folding Team Starter
CL Folding 1,000,000
Default Sliding Causing Transmission Problem?
I'm having a weird issue with my 08 IS-F that is very difficult to reproduce
There is a certain turn which 10% of the time, at higher than average speeds, causes my car to go into "limp" mode
No codes are thrown, no lights come on, it's so weird
I want to attribute the problem to the road itself as it's sandy often, but then I would expect VSC light to flash or something, and not the transmission going in to limp home mode?
Any thoughts?
Old Jun 17, 2019 | 04:56 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
As always the first thing to check and be certain it is correct is the fluid level. I've had the transmission stick in a gear after a hard turn and refuse to shift when in D mode. It will shift by force in M mode, but not in D. So, anytime I suspect the gearbox doing something weird I check the fluid level. It's that sensitive.
Old Jun 17, 2019 | 05:02 PM
vraa's Avatar
vraa
That was my first thought too and I am glad you mentioned it too, I will have Vu take a look at it asap
Very sensitive to fluid it seems, you seem to be spot on about the 'not wanting to shift, even in D mode'
Old Jun 17, 2019 | 05:37 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
I've been experimenting with running about 100 ml (4 ounces) additional after setting the level correctly. It seems to help with this particular issue.
