Engine mounts and subframe question.
Old Sep 29, 2018 | 04:02 PM
jat0223's Avatar
jat0223
Default Engine mounts and subframe question.
I highly doubt this but, can the subframe shift over time, maybe because of potholes or other reasons?
If not then, do motor mounts settle after a few months, specifically the rrracing mounts?
I'm asking this because when I got my second set of headers installed by rrracing with their mounts a few months ago, everything was fine. Nothing rubbed or anything, no clearance issues. But recently I started having clearance issues so I lifted the car up and sure enough the headers are now hitting the subframe so something must have shifted around. It happens mostly when the car is cold, once it warms up, the clearance issue gets better.
What could have shifted? I'm even contemplating installing back the OEM mounts just to see if that's the issue.
btw the gold tape that rrracing installed in my mounts came off and became black (burned) because it stuck to the headers. People with the mounts should check their tape.
Old Sep 29, 2018 | 04:14 PM
RRRacing's Avatar
RRRacing
Sponsor
PPE headers tend to get close to the bottom passenger side of the subframe. In fact with stock mount cars, we always grind away a bit of the flange, but we haven’t had to do that yet with our mounts. It’s pissible there is some manufacturing variability. It’s something that can easily be solved by shimming the mounts just a bit, or if it’s touching the subframe where I think it is, just a minor material removal alleviates any touching.
Rafi
Old Sep 29, 2018 | 04:32 PM
jat0223's Avatar
jat0223
Rafi
they're hitting the subframe right above the lca bushing on the passenger side. They only have like 1/16" clearance.
How would I go about shimmying the mounts? With a washer or something like that?
Old Sep 29, 2018 | 05:37 PM
RRRacing's Avatar
RRRacing
Sponsor
In cases where they hit with stock mounts, that’s EXACTLY where they hit.
I am not sure your name, but if we did the install you are more than welcome to come to the shop and it’s an easy fix.
Rafi
Old Sep 29, 2018 | 07:13 PM
jat0223's Avatar
jat0223
Rafi
my name is John. I'm the guy that switched from the sikky headers to the equal length ppe and got them installed along with the motor mounts at your shop.
Jks24
Nov 18, 2016 08:22 PM
CDY
Mar 30, 2008 09:42 PM
ridah
Dec 20, 2007 12:36 AM
StockGS400
Performance
Nov 26, 2006 12:23 AM
nimit1234
Oct 8, 2006 10:09 AM
