Replace rotors?
Old Aug 17, 2018 | 05:22 PM
Diesel350's Avatar
Diesel350
Default Replace rotors?
I am putting in new pads and I’ve noticed that the rotor surface looks and feels uneven. Rotor thickness is fine. Should I be replacing the rotors or am I fine slapping on new pads with the way the rotor looks?
Old Aug 17, 2018 | 05:53 PM
Neles's Avatar
Neles
Either resurface or buy new rotors. You will regret just slapping the pads back on - as I did learn the hard way. My rotors were just like yours.
Old Aug 17, 2018 | 05:54 PM
Diesel350's Avatar
Diesel350
why do they get like that? My rears are not like that.
Old Aug 17, 2018 | 06:17 PM
MileHIFcar's Avatar
MileHIFcar
Mine were just like that + all the holes had cracks coming off of them when I swapped out mine for new ones. Good question though, have no clue why they have that undulation on so many we see??
Old Aug 17, 2018 | 06:33 PM
Diesel350's Avatar
Diesel350
Yeah I have no braking issues at all. I have 4 mm left on the brake pads. Those are the original rotors that came with the car and they were machined 32,000 miles ago.
Old Aug 17, 2018 | 06:44 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Resurfacing (turning, machining) rotors is never a good idea. It just removes material. If your rotors are structurally fine, no cracks, and you meet the thickness tolerance, just replace the pads. BTW, don't forget to bed in your new pads.
Lou
Old Aug 17, 2018 | 08:12 PM
FinLIFE's Avatar
FinLIFE
Resurfacing rotors can and should be done when you are putting on new pads and if they are still thick enough. Turning rotors should take off very little material. Many years ago when I used to do it we would measure them and take off very little to get them smooth. If they are too thin or have cracks then replace them obviously.
Old Aug 18, 2018 | 04:36 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Just no. Resurfacing is almost always a bad idea. The worst rotors I ever had on my car were resurfaced by someone before I bought them. Never again. The only proper way to resurface a rotor is to centerless grind it, and finding someone to do that is pretty hard at any price. That's how they come from the factory.
The rotors in the pictures need nothing done to them. Be sure they're clean and more than the minimum thickness, slap in new pads, bed them properly and they'll work just fine for anything including track duty. AMHIK.
Old Aug 19, 2018 | 08:13 AM
vertex16's Avatar
vertex16
This. I've NEVER had rotors successfully resurfaced. If the rotors meet minimum thickness and aren't warped, pad slap it and call it a day.
Old Aug 19, 2018 | 08:28 AM
jat0223's Avatar
jat0223
Rotors don't warp.
Old Aug 19, 2018 | 05:26 PM
vertex16's Avatar
vertex16
Originally Posted by jat0223
Rotors don't warp.
Fine, lateral runout and minimum thickness variations then lol
Old Aug 19, 2018 | 05:29 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Rotors don't warp.
That too. Hard spots yes. Warp, no.
Old Aug 20, 2018 | 03:27 AM
banserki's Avatar
banserki
They get all ripply like that because of the cross drilled holes. Definately replace.
Old Aug 20, 2018 | 04:28 AM
Diesel350's Avatar
Diesel350
Hmm we have some people saying replace them and others saying no need to replace. Interesting. Lol. I just came from Lexus and they didn’t even say anything about the rotors. They just said my pads were at 4mm and needed to be replaced.
Old Aug 20, 2018 | 06:43 AM
GaaraOTS's Avatar
GaaraOTS
what is the minimum thickness for the rotors? how do you measure it?
